2008 6.4l rough idle & P0305 code - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-24-2014, 02:41 PM Thread Starter
My 08 6.4l F250 is idling rough, especially in gear with foot on brake. Accelerates fine, no stumbling or hesitation and no lack of power I can notice.
I replaced the EGR valve, fuel/oil filters (OEM), oil, etc...Added some diesel Kleen to the fuel and some Rev-X to the oil.
Cleared the previous code (P0300, multiple/random cylinder misfire) and drove it about 40 miles before code set with P0305, Cylinder #5 misfire.
Coolant level hasn't budged and no other symptoms except the rough idle...which gets rougher if I idle more than a minute or so.
2008 Ford F250 6.4l diesel, 150k miles
james9876 is offline
post #2 of 4 Old 03-24-2014, 06:01 PM
Denny diesel's Avatar
I was having a rough idle issue for a week or so and could not figure out why. The only thing I had done recently was run diesel Kleen gray bottle instead of the ford brand cetane boost. So I stopped using diesel clean and went back to the ford stuff and problem solved. Don't know if this is your issue but might be worth a shot. Just give it a few days without adding diesel Kleen I know some guys like the stuff but my girl did not like it at all lol
Denny diesel is offline
post #3 of 4 Old 03-31-2014, 09:06 PM Thread Starter
Dealer says I have 3 bad injectors: 5, 6 & 8. I've ordered new injectors and have the passenger valve cover off and #5 injector out (see pic). Two of the little plastic rocker clips are broken (cylinders 1 & 3 exhaust valve rocker). I've been searching for the part number or a source for replacements with no luck yet. Do these actually serve any purpose? I hear of broken lifters being blamed on these clips failing, but for the life of me I cannot see how these little dinky pieces of plastic could have an impact of the rocker operation. Is it more likely that when a rocker arm fails, it takes out the plastic clip with it and then the clip is blamed??
post #4 of 4 Old 04-01-2014, 06:33 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
You can buy the whole rocker assembly for about $150. That is what I would do while you have the valve covers off. Part number is 8C3Z-6564-D. It comes with all the rockers for one side and new clips.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
