sudden loss of boost - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-09-2014, 10:22 PM Thread Starter
Hey guys well I'm kinda stuck here. 2008 f250 cc fx4 6.4l 300k miles. Went to Oklahoma this past weekend and on my way back I noticed I couldn't climb past 20psi boost. I usually hit around 25 to 29.
I already checked all turbo piping and didn't see any cracks but I do hear a faint whistle at idle.
Only mods are intake and fully deleted with a dpf-r 4.0 stock tune
Any thoughts be for I head to dealer
maverickxp is offline
post #2 of 4 Old 03-10-2014, 05:58 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Two common things are up pipe and loose bolt on an exhaust manifold. Check the bellows of the up pipes and the firewall for soot. Also check your intercooler boots. Maybe one is leaking
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 4 Old 03-11-2014, 09:23 AM Thread Starter
Om so I found my leak. My drivers side rear exhaust manifold bolt broke. It is still sticking out very far. Just the head of it broke off so I should be able to get vice grips or weld a nut on it easily
How hard is it to remove the manifod. Any tips or tricks to it
post #4 of 4 Old 03-11-2014, 09:39 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I have never messed with one before but I hear its a PITA with the cab on. When my cab came off I also had a broken exhaust manifold bolt. Good luck
08 F350 cc/sb 4X4
