Whistling sound on accel - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-05-2014, 02:40 PM Thread Starter
dweymer's Avatar
2009 F250 SD, just developed this whistle. Only does it on normal accel, NOT while wide open, it gets LOUD. I checked all the intake connections, NADA. Any ideas?
Currently smokeless......
dweymer is offline
post #2 of 6 Old 03-06-2014, 09:40 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Sounds like maybe an exhaust leak. Check the up pipes or possible a loose or broken exhaust manifold bolt.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 6 Old 03-13-2014, 09:34 AM
keech29's Avatar
Had the same problem when the truck was cold, turned out to be a bad flex joint on the down pipe.
keech29 is offline
post #4 of 6 Old 03-13-2014, 09:35 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Up pipe?? The down pipe does not have a flex joint.
08 F350 cc/sb 4X4
post #5 of 6 Old 03-13-2014, 09:40 AM
Quoted: 48 Post(s)
cracked up pipe
drunk on diesel is offline
post #6 of 6 Old 03-13-2014, 09:49 AM
keech29's Avatar
Sorry, meant up pipe
keech29 is offline
