Aluminum in Oil Analysis - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-04-2014, 05:21 AM Thread Starter
mikemass's Avatar
How concerned should I be with this report and what do I do about it? No heavy towing, but the truck has done a lot of snow plowing this winter. Last Feb report was before I did DPF and EGR deletes. This report is after Deletes.
See report attachment from Blackstone:
2008 F-250 FX4 Crew Cab
DPF Delete 4" Straight pipe
Flo-Pro EGR delete w/ intake elbow
Gear Box Z DPF-R + with Economy Tune
78k miles as of April 2016
mikemass is offline
post #2 of 10 Old 03-04-2014, 06:44 AM
Quoted: 2 Post(s)
having the same issue as you with high aluminum. just did a quick mid oil cycle sample with about 1200 miles on the oil and it was high again. I'll post a picture of it today sometime. but here is a thread i started back in january when my levels started getting higher.
Blackstone Oil Reports are getting worse! What do I do now?
basically, in short, unless you know the grade of aluminum they are referring to, you cant be sure exactly which part of the motor its coming from. another thing that was mentioned to me was, think about how many trucks out there that don't get UOA's done that probably have high aluminum levels. and they run for thousands of miles without issue. just a thought.
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #3 of 10 Old 03-04-2014, 07:26 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
As stated it depends on the grade of aluminum. If I had to guess I would think its coming from the pistons. I guess just keep an eye on it.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #4 of 10 Old 03-04-2014, 08:45 AM Thread Starter
mikemass's Avatar
Kris. I just read your last thread on this topic. Don't know why I didn't find it in a search. But wow. That is some high Aluminum levels. Was this sample you did at 1200 miles just as high (127ish)? I am concerned at a 31 reading.
Fatboy: I hear what you are saying to keep an eye on it. But isn't the reason we do OA's is to tackle these issues in the early stages?
Thanks for the replies.
mikemass is offline
post #5 of 10 Old 03-04-2014, 08:52 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Yea man I understand where you are coming from. We do UOA to catch problems before they come big. The problem is no telling where the aluminum is coming from. It could be pistons or other components. If you had coolant in your oil we could probably tell you where its coming from. The problem with aluminum is you would have to know for sure what component it is from. All you can do at the moment is keep an eye on it and see if it continues to go up or maybe it will go down. Maybe it was from ideling a lot while plowing.
08 F350 cc/sb 4X4
post #6 of 10 Old 03-04-2014, 09:04 AM Thread Starter
mikemass's Avatar
Yeah. It has gotten some hard work from plowing. And I mostly do large driveways, and small parking lots. So it's a lot of slow moving forward-reverse, etc.
mikemass is offline
post #7 of 10 Old 03-04-2014, 09:28 AM
Quoted: 2 Post(s)
it ended up being 1400 miles.. but the count was still high. 69 after 1400 miles.. here.. i'll let you see for yourself. the truck runs freaking awesome.. it doesn't miss a beat, i just had it out hauling my dump trailer loaded down with junk, about 8K lbs total on my gearhead Hot Street tune, never once gave me any issues, and then just yesterday , i plowed for 12 straight hours, didn't miss a beat. I love this truck, but this aluminum stuff has me worried.
Kris
post #8 of 10 Old 03-08-2014, 05:38 AM
Quoted: 11 Post(s)
Not trying to start a BS oil argument but out of curiosity, what motor oil are you running? I read a couple oils can cause high aluminum, so I switched my oil and will be finding out if it's really a factor for my truck.
nater6.4 is offline
post #9 of 10 Old 03-08-2014, 06:19 AM Thread Starter
mikemass's Avatar
I'm using the Ford MotorCraft 15w-40 diesel blend for Powerstrokes.
mikemass is offline
post #10 of 10 Old 03-08-2014, 06:21 AM
srjd's Avatar
Quoted: 2 Post(s)
Some oils I'm sure will cause a jump in ppm but not jumps like we are seeing here
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
