Turbo shaft play - Ford Powerstroke Diesel Forum
post #1 of 1 Old 03-03-2014, 07:27 AM Thread Starter
TD-5's Avatar
Quoted: 3 Post(s)
Turbo shaft play
Does anyone have the tolerances for maximum axial & radial play in the shafts on both the LP & HP turbos.
Of course if the wheel is contacting the volute housing its junk, but how much play can these be run with before it should be condemed?
My HP has about .020" of radial.
2010 F350 KR CCLB, mini max, H&S pyro kit, ARP studs, II 71/59 billet turbos, RCD ported intake, ceramic BD 6.0 exh manifolds, stainless uppipes, SDP 4" ceramic downpipe, 5" MBRP stainless, sinister egr delete with intake elbow, 3" CAC cold side pipe, BD boots, AFE custom air intake, AirdogII, Mann&Hummel CCV filter, 4.10 Yukon locker rear, Eaton TrueTrac front, Coolant filter
TD-5 is offline
