Motor problems - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-24-2014, 09:46 AM Thread Starter
Motor problems
I have an 08 6.4l with 180k on it. Heat in cab not good, turbo psi is at 10 when going down the highway not pulling anything and goes up to 20 or 30 on a slight incline or if I'm going from a stop up to speed with 1/2 throttle it's up there also some times goes to 40, very heard on fuel right now. Anyone have these problems and might have a solution
Leroy A is offline
post #2 of 3 Old 03-17-2014, 12:31 PM
Check tube the ebp sensor. Mine snapped and was doing this. Could be plugged
kerpal312cs is offline
post #3 of 3 Old 03-17-2014, 03:00 PM
try removing and clean the MAP sensor, they get carboned up. Its the 27mm 3-pin sensor on passenger side on the intake manifold right by when the air intake meets the turbo. I usually use a very thin phillips screwdriver and some pb blaster, but that hole in the sensor goes pretty deep
Scumbag is offline
