Ebp? Overboost. Now engine click/knock - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-23-2014, 07:22 PM Thread Starter
Coming home from work about a week ago engine came on P2263 boost was high and I had no power. Cleaned the EBP took the truck down the road didn't make it 1/8th of a mile intercooler pipes blew and engine is now making noise. I wasn't gettin on the go pedal but maybe 30%.
I pulled the oil pan. No sign of any damage.
I pulled connecting rod caps and checked the bearings. I did have some noticeable wear. No signs of damage to crank or rods themselves.
So I went ahead and replace the the rod bearings with a set from Ford. Not bad ($65)
Finished the truck up today. Fired it back up with the exact same noise.
64stroke is offline
post #2 of 7 Old 02-23-2014, 07:37 PM Thread Starter
Sorry guys I'm trying to post a video with the noise but can't seem to figure it out.
64stroke is offline
post #3 of 7 Old 02-23-2014, 07:40 PM Thread Starter
I meant to add it has mini max, full delete, 5" straight pipe, airaid intake. The tunes are mild. I usually keep it on "tow".
64stroke is offline
post #4 of 7 Old 02-24-2014, 06:23 PM Thread Starter
I can email someone a video clip if need be.
64stroke is offline
post #5 of 7 Old 02-24-2014, 06:29 PM
michaelite's Avatar
Quoted: 9 Post(s)
There's a link in forums>General Topics>Forum Help and Info. That hopefully can help you upload a video
michaelite is offline
post #6 of 7 Old 03-08-2014, 08:00 PM
Upload the video and then post a leak.
Could be push rods
GSchretter is offline
post #7 of 7 Old 03-15-2014, 09:39 PM
I had an excessive boost problem once that involved too much fun, and stock valve valvetrain. I ended up bending a couple of rocker arms. It was popping out the intake on every other revolution. I don't know if that is the kind of noise you are describing.
Eli Benson - EMT, Ambulance Mechanic
'08 F350 Dually KR - Spartan'd
'07 F250 CC SB 4x4 XLT - SCT /w Innovative Tunes
4 '09 & '10 E350 6.0l ambulances
1 '08 Duramax 6.6 (LMM) van ambulance
elibenson is offline
