Decent oil leak Blown turbo or seals or more? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-16-2014, 07:52 AM Thread Starter
I started my truck this morning and let the truck get up to 140F before I left the house. I didn't even make it a mile when I noticed it was smoking profusely out the tailpipe when a car pulled up behind me. I made it to the next street where I turned off and popped the hood it smelt like oil in the engine bay. My truck is fully deleted and am venting into the atmosphere with a 1" hose and I noticed that it still had built up pressure inside the oil fill which I don't think it ever has. I saw some oil residue in the hot side pipe and copious amounts of oil in the exhaust. I don't know enough to definitively tell if it is just a seal or one of my turbos blew or if this is something worse? I don't beat on my truck ever and rarely get on it but I keep within safe paramaters.
Thank you to all who help and can tell me where to start with this. I don't have a garage so I can't do much until I get to one.
P.S. Truck has no loss of power from what I could tell, has no missing or odd feel to it, coolant still looked like it should.
Fussgus is offline
post #2 of 10 Old 02-17-2014, 06:16 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
So there wasn't oil all over the engine bay but just mostly in the exhaust? Is there a lot of blowby coming out the oil fill when you start it?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 10 Old 02-17-2014, 04:59 PM Thread Starter
Yup there was quite a bit. Even with the CCV vented to the atmosphere there was still pressure under the cap when I spun it off. There is zero oil in the engine bay.
Fussgus is offline
post #4 of 10 Old 02-18-2014, 08:03 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Sounds like it could be a piston
08 F350 cc/sb 4X4
post #5 of 10 Old 02-18-2014, 11:23 AM Thread Starter
That's definitely something I wanted to hear
Fussgus is offline
post #6 of 10 Old 02-18-2014, 12:04 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I really hope its not man but its kind of sounding that way.
08 F350 cc/sb 4X4
post #7 of 10 Old 02-18-2014, 01:37 PM Thread Starter
So I figured out the problem and hopefully no damage was done. My 1in CCV hose that ran to the back of the cab developed a sag in it where moisture built up and froze which preceded to block of any venting all together. I cut the hose just behind the fender wall and it now has a straight shot down to the ground.
Do you think I may have been spared and no head gasket damage was done? Or any damage in general? I didn't run it like that very long.
Fussgus is offline
post #8 of 10 Old 02-20-2014, 06:20 PM
silver93's Avatar
my high pressure turbo had about 1/2 slack in the center section and damaged the seal which was allowing engine oil to get by and was pushing it into the intercooler and into the engine. I ended up putting a motor in my truck because of the turbo. I got down on the truck and all of a sudden smoked poured out of it and it killed. when I tried to start it back it would barely turn over. I had only had the truck maybe 12 hours pulled it back home to find it only had 7 quarts of oil in it. finally got it to start back up but had a bad knock. come to find out it had bent a rod because the turbo was actually sucking the oil out the engine and pushing it into the engine and when I got down on it it forced a bunch of oil into one of the cylinder and could not burn it and being liquid doesn't compress some thing had to give so it bent a rod. if I was you I would pull the piping from the high pressure turbo and see if you have slack in that center section. it aint hard to do and could save you a engine and a lot of $$$$$ if that is the problem..
silver93 is offline
post #9 of 10 Old 02-20-2014, 07:21 PM Thread Starter
I did that and it still has hardly any play at all in it. It's been 3 days now and it runs great as it always has.
Fussgus is offline
post #10 of 10 Old 02-20-2014, 07:43 PM
silver93's Avatar
Good deal.
silver93 is offline
