Cold chirp - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-11-2014, 06:19 PM Thread Starter
DOHC's Avatar
Cold chirp
Searched,,,, Read,,,,,Searched,,,, Read,,,, Is there a fix for the belt chirp? Or is it several issuse, thats why no one can pin point the problem?
DOHC is offline
post #2 of 6 Old 02-11-2014, 07:36 PM
srjd's Avatar
Quoted: 2 Post(s)
Many people have pin pointed it. Its usually the idler pulley or belt tension or. I've had both go the idler really caused the chirp only on cold start up
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #3 of 6 Old 02-11-2014, 07:42 PM Thread Starter
DOHC's Avatar
Just replaced tensioner and top idler less than 500 miles ago. Changed new factory belt to gates green belt and it got loader
DOHC is offline
post #4 of 6 Old 02-11-2014, 09:46 PM
srjd's Avatar
Quoted: 2 Post(s)
Hmm its gotta be something. There's that other guide wheel. Is there only one idler?
srjd is offline
post #5 of 6 Old 02-12-2014, 06:23 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Replace both belt tensioners and idler pulleys while you are at it.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #6 of 6 Old 02-13-2014, 05:11 AM
Powerstroke Techie
Quoted: 380 Post(s)
run it without the serp belt on and see if the noise goes away. if it does, you've isolated it to alt, one of the 2 idlers, ps, wp, or crank pulley. if it doesn't, remove the ac belt and run it. if it goes away, you know whete it is. both tensioners seem to be fairly problematic on these engines
the richest ones are not those who have the most, but those who need the least
**i don't use capitals. deal with it**
kaya is offline
