spent 4k and still the same problem - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-08-2014, 05:41 AM Thread Starter
Hey guys, i have a 2008 Ford 350 with the 6.4L
I took it to the dealer because when the truck starts cleaning the dpf, I lose power. It bucks and cant go over 45mph. getting code p0088
The Dealer replaced 2 injectors, HPFP, Cleaned the dpf, Change the Fuel Filters, and new oil change, and reflashed the computer
After I picked it up the truck it ran fine, then the Dpf started cleaning itself every 80 miles again and did not cure the problem. Im having white smoke come out from the hood and that leaks into cab when the heat is on. And a total lose of power.
I brought it back in and they told me it was because its cold outside and the dpf isnt cleaning itself. I asked them why did they replace the parts they did if the orginal problem was injectors and HPFP. It was because they found metal shavings in the Fuel filter housing.
Im beginning to think it is my low pressure fuel pump that is bad. Because it runs fine when the truck isnt cleaning. My code now is P0087. No CEL but its stored in there.
This truck is compleatly stock. Its a utility truck weighing in about 13k-14k pounds. Carrying a load like that should have no problem heating up the dpf.
Can anybody give me suggestions? The ford dealer keeps brushing it off when we call them. I have called the Corp center for ford and filed a complaint but they also said i need to deal with this dealer.
Thank you,
Nick
2008 F350 Standard Cab utility trucks, 6.4L, 4x4, Stock
NorthernDoor is offline
post #2 of 7 Old 02-08-2014, 07:32 AM
Cold has nothing to do with regen and every 80 miles sounds like the DPF is getting clogged with oil.
I'm most likely wrong but I've been hearing about this problem
Your turbo oil seal is leaking will cause constant regens.
The smoke thing in the cab really bugs me as it sounds like they didn't put everything back together or does this happen only in regen?
Have you thought about deleting the DPF?
You will need a DPF delete pipe and tuner.
IM we can talk about this.
Metal shaving means a shot HPFP but they should of replace everything in the fuel system from Low in pump to high end pump and lines.
I call your CC and ask them about holding payment as they didn't fix your problem but only guessed at what's wrong.
GSchretter is offline
post #3 of 7 Old 02-11-2014, 07:02 AM Thread Starter
Thanks for the Reply,
The smoke deal was happening before i took it to the dealer.
IL Safety Lane will not allow me to do a DPF Delete. We have to get the trucks checked every 6 months here.
Even though if i did do the delete, It would solve all my problems, but that's why I brought it into ford to get it legit fixed.
I'm stumped as of now.
Nick
post #4 of 7 Old 02-13-2014, 05:21 AM
Powerstroke Techie
Quoted: 415 Post(s)
hmm. they didn't do the rail pressure sensor? i agree with gs. it's a tough pill to swallow, but metal flakes calls for a replacement of damn near the entire fuel system. and a thorough flush. it really depends on how much you find though. you're going see slight amounts of shimmer in the secondary bowl when you shine a flashlight. slight. you kind of need to gauge normal from excessive
the richest ones are not those who have the most, but those who need the least
**i don't use capitals. deal with it**
kaya is online now
post #5 of 7 Old 02-13-2014, 06:48 AM
Rocweiller's Avatar
Quoted: 2 Post(s)
Should have saved some of that cash and used on a spartan tuner, cai and exhaust.
2008 F250 XLT SBCC grey flake, 33x12.50 Toyo m/t's on 18 inch mammoth wheels. Rhino lined go rhino nerf bars. S&B cai,Spartan tuned and straight piped. Fake *** chrome grille removed and a matching colored grille put in place.
Rocweiller is offline
post #6 of 7 Old 02-13-2014, 07:08 AM
Never mind
post #7 of 7 Old 02-13-2014, 07:22 AM
x148's Avatar
I don't work on 6.4s much but I recently replaced turbos on a 6.4 due to a loss of oil pressure that cooked them. The dpf was also clogged and would not leave limp mode, the dpf was cleaned/baked from a shop with a final flow rate or 98%. The truck would still regen and not leave limp mode, we put a wrench in between the dpf and engine and turned out the new clean dpf installing clogged after start up. Putting a wrench in between the dpf and exhaust pipe allowed enough exhaust to hit the dpf but also to escape and prevent backpeessure and sure enough truck ran perfect, new dpf again and like brand new truck no issues.
05 F350
-Sinister EGR Delete
-Banks High Ram
-Blue Spring
-Air Dog II
-K&N Intake
-H&S Mini Max
-Swamps 58v FICM
-03 Turbo
-5" MBRP turbo back
-ARP Head Studs
-Cat ELC1 Coolant
-6" Lift on 37" Toyo M/T
-Detriot True-Trac with 4.56 Gears
-Pro Comp Trac Bars
x148 is offline
The Following User Says Thank You to x148 For This Useful Post:
NorthernDoor (04-02-2014)
