Very high pitch squeal only at idle - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 19 Old 02-07-2014, 09:18 AM Thread Starter
Truck is a 6.4L 08' with 107k miles, intake, exhaust, tune and dpf delete.
Current issue:
When I start the truck I have no audible noise and everything sounds good, then after warming up 3-5min I'll get a VERY loud squealing/tea kettle noise only at idle. Once I start driving it goes away and then starts back up after I stop and idling for a couple minutes.
Things I've tried:
Turning on the A/C compressor on/off and no change in pitch.
Spraying WD-40 on belt trensioner, no change.
spraying belt dressing on belts, no change.
spraying water on belts, no change.
Anyone have these symptoms and found a solution?
cupa-joe is offline
post #2 of 19 Old 02-07-2014, 10:45 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Sounds like it might be an up pipe leak. Is your boost down? Any soot on the firewall or around the bellows?
GSchretter likes this.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 19 Old 02-07-2014, 11:00 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
I second that!!!
My truck was doing the same thing and it turned out to be an up pipe leak due to a crack in one of the bellows (flex joints).
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #4 of 19 Old 02-07-2014, 11:15 AM
ADMIN AND TECH
SCUFFY828's Avatar
ill say exhaust leak for sure , more than likely an up-pipe
ITS STOCK
SCUFFY828 is offline
post #5 of 19 Old 02-07-2014, 12:20 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Also broken exhaust manifold bolts are fairly common. I had one when I switched to 6.0 manifolds.
08 F350 cc/sb 4X4
post #6 of 19 Old 02-07-2014, 12:52 PM
Alberta Advantage's Avatar
Quoted: 20 Post(s)
I'd get a high pitched squeal from bent/misaligned tensioners. I've replaced several tensioners as well as a couple belts and my truck only has 60k miles on it. I know you've tried to eliminate the squeal with belt dressing and luring up the tensioners but how do your tensioners look?
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #7 of 19 Old 02-08-2014, 07:19 AM Thread Starter
Yeah I read it could be a flex pipe, so I'll have to grab a mirror and take a closer look. Didn't see any soot, but hopefully a closer look can confirm this.
The auto tensioner looks okay from what I can see although I know it can appear to be fine until removing it. I'd like to start with the easier/cheaper things and go from there.
Replacing up-pipe would require pulling the cab correct?
cupa-joe is offline
post #8 of 19 Old 02-08-2014, 09:24 AM Thread Starter
I know the up-pipe seems to come up when searching but the part that gets me is would'nt the squeal get worse with more exhaust flow? Also no noticable loss of power or more then normal turbo lag.
cupa-joe is offline
post #9 of 19 Old 02-08-2014, 10:16 AM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
easy way to check if it is the belt is to remove it and start it up. if it squeals it's not the belts. it doesn't squeal it is something belt related, a pulley, bearing, the belt etc.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #10 of 19 Old 03-16-2014, 07:10 AM Thread Starter
Okay, well I removed the belt and the squeal/whistle is still there and now seems to move with rpms from idle to 2k ish. Also noticed it goes once I start moving(underload).
cupa-joe is offline
