Power Surge between 1700-2100 Rpms - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-02-2014, 01:03 PM Thread Starter
I have a six speed 6.4 liter 2008 ford f250. when driving down the road between about 1700-2100 rpms it starts to surge or give like a jerking filling until you go above or below this rpm. Shows no codes when on computer and does have the EGR delete kit and 4" exhaust with H&S programmer. Even when removing the programmer it doesn't change No one seems to know how to fix it Anyone have any ideas?
bcgrizzell is offline
post #2 of 5 Old 02-02-2014, 10:26 PM
Put the tuner on mild and see if it does it. I think I had the same problem. That seemed to work.
o4ep3civ is offline
post #3 of 5 Old 02-02-2014, 10:29 PM
Are the coolers just deleted or the coolers and egr valve. The h&s on easy still actuates the egr valve. I felt the same thing. I changed the tune to mild and it stopped. So in my issue (still have full egr) it had to do with that.
o4ep3civ is offline
post #4 of 5 Old 02-03-2014, 12:35 PM
TD-5's Avatar
Quoted: 3 Post(s)
Just an off chance, But are you running the Mini Max & if so what firmware version?. There was a surge issue addresed @ version 6.4.41 Oct 10 2012.
this issue was also addressed for the XRT Pro (6.4.19) & for the Black Max (6.4.38)
http://www.hsperformance.com/tuner-v...e-history-log/
2010 F350 KR CCLB, mini max, H&S pyro kit, ARP studs, II 71/59 billet turbos, RCD ported intake, ceramic BD 6.0 exh manifolds, stainless uppipes, SDP 4" ceramic downpipe, 5" MBRP stainless, sinister egr delete with intake elbow, 3" CAC cold side pipe, BD boots, AFE custom air intake, AirdogII, Mann&Hummel CCV filter, 4.10 Yukon locker rear, Eaton TrueTrac front, Coolant filter
TD-5 is offline
post #5 of 5 Old 02-09-2014, 09:02 AM
Powerstroke Techie
Check the EBP tube for plugging/freezing as well.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
