Drip Drip Drip... Coolant Leak - Ford Powerstroke Diesel Forum
post #1 of 15 Old 01-25-2014, 01:11 PM Thread Starter
Quoted: 45 Post(s)
Found a small leak from my truck this morning... Great. Looks like it may be the hose or the thermostat or such. Really not sure. Any ideas?
Pictures taken from under the driver's side, bottom is facing forward...
2015 F350 DRW Platinum, SCT X4, EDGE CTS2, aFe PDS, AirLift 5000 Ultimate & Wireless Air, Lund LED Bull Bar, RC Grille bar, B&W 5th Wheel, Stark LED Lighting
2010 F250, H&S Mini Maxx, aFe PDS, Diamond Eye 4", Pro Comp Nitro 2.5", Bilstein 5100, SmittyBilt Bull Bar, Bushwacker Pocket Style, B&W Slider, Firestone Ride-Rite, Fuel Hostage 20x10, Pioneer/Kicker/JL Audio
RUFFSTUFF is offline
post #2 of 15 Old 01-29-2014, 03:11 AM
B585Ford's Avatar
I am not at my computer so I cant see the pics but do you have updated hoses that have 2 o-rings?
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #3 of 15 Old 01-29-2014, 04:36 AM Thread Starter
Quoted: 45 Post(s)
I have whatever hoses Ford put on the 2010...
post #4 of 15 Old 01-29-2014, 04:51 AM
I also have found a similar coolant leak on my truck. Does the line that runs from the power steering reservoir to the block have a good amount of coolant on the bottom?....I still have not found the source of my leak.
6.4LTurbo is offline
post #5 of 15 Old 01-29-2014, 05:02 AM
B585Ford's Avatar
I can't remember when Ford made the revision. IIRC at the connection if it is white it is the updated one.
B585Ford is offline
The Following User Says Thank You to B585Ford For This Useful Post:
RUFFSTUFF (01-29-2014)
post #6 of 15 Old 01-29-2014, 07:14 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Yes check to see if both the upper and lower hoses have white ends. Those are the updated hoses.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
The Following 2 Users Say Thank You to 04hdfatboy For This Useful Post:
B585Ford (01-29-2014), RUFFSTUFF (01-29-2014)
post #7 of 15 Old 01-29-2014, 08:49 AM
I had the same leak from the same area. It was the thermostat gasket. I bought the kit from psdparts.com that consisted of the two motorcraft thermostats with gasket , and the upgraded dual ring hoses for both the lower and upper. (white ends) , filled back up with Rotella ELC. All appears good no more leaks. If I remember correctly the whole kit mentioned above was @$135 not counting the coolant.
Here is the URL - http://psdparts.com/store/index.php?...roducts_id=342
onefastrt is offline
The Following User Says Thank You to onefastrt For This Useful Post:
post #8 of 15 Old 01-29-2014, 02:05 PM Thread Starter
Quoted: 45 Post(s)
Thanks for the info!
post #9 of 15 Old 01-29-2014, 03:42 PM
B585Ford's Avatar
Thanks for confirming the white one is the updated one.
B585Ford is offline
post #10 of 15 Old 01-29-2014, 05:24 PM
Mine is doing the same thing. My Lower radiator hose is leaking at the engine. Just got my box of parts from PSD parts today with the upgraded hoses and t-stats. My 2010 did not have the updated hoses on it. Paid 144 for the kit I believe.
Rumrunner is offline
