Cold Weather - No Start - P2291??? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-25-2014, 09:50 AM Thread Starter
Background: Truck has been running great with no issues. About 2 weeks ago, I had a friend who totalled his truck, and had a aux tank in his bed. We drained the fuel from that into my truck. After about 10 gallons were in the truck my buddy noticed a lot of water in the transfer line. Long story short, we stopped and I had to drain my water bowl under the truck about once every 2 days, but I had a full tank for the most part. About 4 days ago, the little plastic drain valve lever broke off the lpfp on the frame rail, so I have not been able to drain. I parked the truck last night (still no performance issues or codes other then water in fuel: P2269). Was low on fuel (low fuel light on), thought I was going out last night, but didn't so I plugged it in and it sat overnight. Got down to about 9 degrees last night.
Went out to pull the truck out of the driveway this morning. Crank, crank, crank... nothing and it displayed the wrench and 2 codes: P2269 and P2291. Took another truck to do what I had to do, stopped by the parts store, grabbed new fuel filter set. When I pulled the filter out of the LPFP, there was a lot of grit and water that came out with the filter. Clean out the bowl as best I could with brake clean and let it dry then put in the new filter.
Cycled the key twice and tried starting, nothing... Changed out the filter on top of the motor. When I pulled out this filter, again more grit and water. Drained the main bowl and scrubbed the bottom of the bowl. Put in the new filter and sealed it back up. Cycled the key 6 times, cracked the engine filter cap and let the air bleed out. Then cycled 2 more times and bleed the air one more time. Cycled the key until the pump turned off 2 more times.
Still nothing, any help/ suggestions? Could this just be frozen water in the lines somewhere clogging something? I did put in 5 fresh gallons of diesel today with a cup or so of diesel kleen.
HELP!
OrangeBronc79 is offline
post #2 of 3 Old 01-27-2014, 06:16 PM
had almost the same situation other then I got bad fuel from a pilot, drove 15-20 minutes drain light came on pulled over drained it and then i couldnt keep it running. Took it to the dealer being that i was 2hrs away from home they dropped the tank relaced both fuel filters changed oil flushed fuel system other then rails.They couldnt find the issue but think water could of frozen in the HPFP or an injector/s and busted them.havent had much luck figuring anything else out yet.If i do find out anything Ill let you know.
greedygenius is offline
post #3 of 3 Old 01-27-2014, 07:58 PM Thread Starter
Anybody know the part number for the banjo fitting?
Atleast then I can make my own bleed tool and try it.
