CODE: P006B ?? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-02-2014, 07:48 AM Thread Starter
DieselPowerFan's Avatar
CODE: P006B ??
Started my truck up this AM, it's -32 C, had my block heater plugged in overnight, and the engine light came on. So I check for codes with my Mini Maxx, says code: P006B. I did a quick search on the net says: P006B MAP/Exhaust Pressure Correlation. What gives?
I have a banks intake, flo pro down pipe and 5" exhaust, CAC pipe.
Thanks
DieselPowerFan is offline
post #2 of 4 Old 01-06-2014, 07:36 PM
Frozen DPF.
Check for a restricted exhaust
VictorFordTech is offline
post #3 of 4 Old 01-07-2014, 03:52 AM Thread Starter
Thanks for the reply no DPF on my truck and the exhaust is flowing good. Took it to the dealer they said oil from my banks air intake was clogging the MAF sensor? Said they cleaned it code came on again next day.
post #4 of 4 Old 01-07-2014, 09:46 AM
TD-5's Avatar
Quoted: 3 Post(s)
Possibly the MAP sensor is defective, I'm suprised the dealership actually cleaned it & didn't just replace it. Are your EGR coolers deleted? If so, it could also be the EP sensor is plugged or has frozen moisture in the tube. This is quite common on deleted trucks.
#6 in the picture.
2010 F350 KR CCLB, mini max, H&S pyro kit, ARP studs, II 71/59 billet turbos, RCD ported intake, ceramic BD 6.0 exh manifolds, stainless uppipes, SDP 4" ceramic downpipe, 5" MBRP stainless, sinister egr delete with intake elbow, 3" CAC cold side pipe, BD boots, AFE custom air intake, AirdogII, Mann&Hummel CCV filter, 4.10 Yukon locker rear, Eaton TrueTrac front, Coolant filter
TD-5 is offline
