Loud metal squeel - Ford Powerstroke Diesel Forum
post #1 of 15 Old 12-14-2013, 09:33 PM Thread Starter
Dykzeulb's Avatar
Loud metal squeel
I was bringing home my daughter and her friends from the movies doing about 35 mph, and the truck started making a metal on metal squeel, I couldn't tell where it came from so I slowed down immediately, the squeel continued. I locked in 4x4 auto and reved it some to check the boost pressure, still there, and then the squeel stopped. Wasn't any more than 30 seconds long, and I continued to drive checking gauges, everything looked fine. It didn't come back as of yet. I am hoping maybe a rock got in the break as I live on gravel . But are there any problem areas I need to check to be safe? Turbos? Bearings? I checked the turbo fin when I installed the intake, and it have maybe a mm or two of play but not much, boost pressures looked fine. Egr Is still on but disabled with mini Maxx. Help?!
2009 Ford F-150 Lariat
Dykzeulb is offline
post #2 of 15 Old 12-14-2013, 09:37 PM Thread Starter
Dykzeulb's Avatar
After watching a few turbo squeel videos on YouTube, I think that's the culprit. What now? Replace/ rebuild? How to check?
Dykzeulb is offline
post #3 of 15 Old 12-15-2013, 05:32 PM
Could be fuel cooler pump. Check the fluid level and top off as needed.
DisposableHero is offline
post #4 of 15 Old 12-15-2013, 05:42 PM Thread Starter
Dykzeulb's Avatar
Fuel cooler pump? I topped off the coolant today, will be watching closely
Dykzeulb is offline
post #5 of 15 Old 12-16-2013, 06:36 AM Thread Starter
Dykzeulb's Avatar
I am losing a decent amount of coolant somewhere, drove about 10 miles and lost around a 3/4" out of the degas bottle from when I filled it up before leaving. I am not seeing anything leaking down creating a puddle, nor am I seeing any in the oil. I did see a front oil pan gasket leak, although minimal. I will need to be getting it fixed. So.. I have had a loud metal on metal sounding squeal, losing coolant, but not getting hot yet. I am running the Mini Maxx, 5" DP back pipe, S&B intake. Any ideas of areas to check for coolant leaking or seeping? I don't know these engines all that well.
Dykzeulb is offline
post #6 of 15 Old 12-16-2013, 06:42 AM Thread Starter
Dykzeulb's Avatar
Where is the fuel cooler pump located? Would it display some form of fluid leaking?
Dykzeulb is offline
post #7 of 15 Old 12-16-2013, 06:44 AM
Fuel cooler pump is attached to lower fan shroud, left side of rad.
Hauser is offline
post #8 of 15 Old 12-16-2013, 08:40 AM Thread Starter
Dykzeulb's Avatar
I assume there are hose connections? I looked at a photo of the part on Tascas website, looks like two small lines connecting. Would it be leaking from those joints, or are they known to leak from the actual housing? Looks like a smaller water pump...but plastic.
Dykzeulb is offline
post #9 of 15 Old 12-16-2013, 11:09 AM
TD-5's Avatar
Quoted: 3 Post(s)
The fuel cooler cooling system is a separate system from main engine cooling. Its the small tank with sight glass to the rear on the LH side with the small pressure cap. If you are losing coolant from the main Degas tank then the leak doesn't involve the fuel cooling. Possibly the squeal was the water pump bearing & the seal is now leaking?. check for leakage around the front of engine.
2010 F350 KR CCLB, mini max, H&S pyro kit, ARP studs, II 71/59 billet turbos, RCD ported intake, ceramic BD 6.0 exh manifolds, stainless uppipes, SDP 4" ceramic downpipe, 5" MBRP stainless, sinister egr delete with intake elbow, 3" CAC cold side pipe, BD boots, AFE custom air intake, AirdogII, Mann&Hummel CCV filter, 4.10 Yukon locker rear, Eaton TrueTrac front, Coolant filter
TD-5 is offline
post #10 of 15 Old 12-16-2013, 11:32 AM Thread Starter
Dykzeulb's Avatar
What about my EGR? Will there be any indication as to whether it is leaking or not? I haven't installed my kit yet.
Dykzeulb is offline
