No coolant flowing - Ford Powerstroke Diesel Forum
post #1 of 2 Old 12-06-2013, 06:48 AM Thread Starter
Zachf's Avatar
No coolant flowing
i started my truck yesterday it was pretty cold out went about 10 miles down the highway and the coolant started to get warmer then usual, and the heat was ice cold. I pulled off looked under the hood and there was steam coming the top of the radiator i was low on coolant and the lower hose was cold. I think it could be the thermostat is stuck. Any other ideas has this happened to anyone? thanks
08 F-350 6.4 Lariat FX4 ccsb, southbend single disk, Spartan, egr delete, 4" turbo back, afe intake
Zachf is offline
post #2 of 2 Old 12-06-2013, 07:17 AM
Term3's Avatar
Not up on 6.4's but the Ford thermostat usually fails open, other brands could fail closed. If the 6.4 water pump is like the 6.0 which is a plastic composite it could be cracked or missing some fins. Next thought is bad head gasket.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
