Go Back   Ford Powerstroke Diesel Forum > Ford 08 and newer 6.4L Powerstroke Forums > 6.4L Problems Forum > 6.4 Motor Problems
Old 08-27-2008, 08:20 AM
BUKWAKR BUKWAKR is offline
STRANGE TURBO NOISE
OK
I was out doing some datalogging for Scott@ Spartan and did a few power brakes it was spun up pretty good and I lifted out of the pedal quick then heard a hissing sound come from the turbo area, now it does it all the time even if it's just doing 50 down a road and then shutting down the pedal it's not vgt flutter it sounds like one of those wrx's with the waste gate turned way up. I'm going to look at the cac lines and the intercooler but it never did this before.
Darrell
Old 10-21-2009, 02:23 PM
Rotorfixer Rotorfixer is offline
what did you find out? mine started this at exactly 1000 kms.... I am assuming it is normal, worst is @ 80 km/h and apply throttle, while the RPM is down, lots of hissing from the drivers side.
Old 11-01-2009, 01:31 AM
sirdarkveil sirdarkveil is offline
I had a loud hiss or blowing sound that was a intercooler connection boot that was blownout. It had a hole that my finger could fit into. Step into throttle, boost pressure goes up and sound level increases. Now I have a flutter sound that seems to be on the increase. The turbo was rebuilt by a shop about 2 months ago.
