6.4 Motor Question?? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-02-2013, 07:32 PM Thread Starter
I have purchased a '08 F350. The person that i purchased it from paid Ford to tear the motor apart to find a engine noise.
They tore the heads off the engine and told them it had a bent connecting rod.
They had an extended warrenty that refused to fix it saying they had injector
issues and that was what caused the problem.
They refused to pay to fix the truck or put it back together. I bought it apart.
So over the long weekend I took the short block out. Got the engine tore apart
tonight.
The engine is VERY clean inside. The stamp date on the bearing is 9/11 meaning the bearing were manufactured the 9th month of 2011.
So this is not the orginal engine to this truck. My question is would Ford have put a short block in this truck or did they only do long blocks??
The crank and rod bearing are all in good shape. So I guess I'll just rering the
engine and do head gaskets and head studs and reinstall???
I have the tuner,S&B CAI,I/C up grade pipe,high flow elbow w EGR cooler delete. What else should I do while the truck is apart???
Not sure on Larger down pipe??
Was going to get the injectors checked out. Diesel Injection said they could check them out and increase the flow 50-75 HP??
Also thought of having the turbos checked out. The V/V turbo was stuck
when i got the truck so I pulled it apart and got it freed up
Any ideal on how could check the turbos out that would be FAIR??
Open to any input
The truck will be used for towing a 35ft 5th wheel camper, 3 car wedge bed trailer and a 32ft enclosed trailer.
I currently have a '00 7.3 dullay that does the job fine now just wanted to
have a new/quieter truck
THANKS in advance
Fastcat is offline
post #2 of 4 Old 12-03-2013, 06:36 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
If you have the money while its apart do new pistons. Also with that many miles put all new rockers and push rods. I also would do a 4" down pipe. The stock bottom end is very stout. As far as adding fuel I would not add fuel until you add air (bigger turbos, ported intake manifold). Also in order to do bigger injectors you will need dual fuelers. The HPFP will not keep up with bigger nozzles. As far as checking the turbos maybe try barder turbo service. I have heard good things about them.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 4 Old 12-03-2013, 08:15 PM Thread Starter
What is the issue with the stock pistons?? The piston in it are Mahl brand. Are these stock?
Should the rockers be replaced or can I just replace the plastic(?) bushings
Dual fuelers what is that?? Is that like a airdog (lift?) pump set up
Is barder turbo a vendor on here or do you have a number??
Which part of the intake are they porting??
Is that something I can do or is there a place that does it?? Are we speaking of the
"U" shaped were it mates to the heads??? It has a bunch of crud/carbon like build up in it, i'm having it hot tanked to clean all that crap out of it and the elbow near the T/B
So with the H&S Mini Max (R) version there is no need for the bigger nozzels??
Thanks for the advice
Fastcat is offline
post #4 of 4 Old 12-04-2013, 06:51 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Sometimes the stock pistons crack. It has to do with the lip on the piston bowl.
I would replace the whole rocker pedestal. It can be had for about $150 a side.
It is a duel k16 fueler setup. It is needed for more fuel. Personally I would just stick with stock fuel.
Rudy's Diesel Twin K16 High Pressure Fuel System
Yes barder turbo service is a vendor here. You can google them to get the number. I don't have it offhand.
They are porting out the restrictions inside the intake manifold. It is cut open, cleaned out and welded back together. A ported intake will flow better than stock and reduce egt's. Unless you know what you are doing I would have someone do it. Mine was done by a member on here (windrunner408). His name is Nate. He is very reasonable as far as price.
No there is no need for bigger nozzles.
08 F350 cc/sb 4X4
