Questions on rocker arm replacement - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-02-2013, 06:37 AM Thread Starter
live for the now
ZombieSoldier's Avatar
I had my truck looked at over the weekend to figure out what was wrong with my truck the rattling. Josh from Darkhorse Diesel did an injector scan and ran a compression test and can't conclusion that the rocker arms worn out. so he recommended I get all new rockers to put in the truck. now my question is what all parts do I need in order to do this? obviously the rocker arm assembly what you can get complete assemblies for each size and what do that but what else do I need? How long should it take for a novice person to be able to do this job.
2008 F250 6.4 - a little of this, a dash of that and soon you have made a truck the way Ford should have made it!
ZombieSoldier is offline
post #2 of 4 Old 12-02-2013, 07:12 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I believe you will also need the 4 jumper tubes that go from the fuel rail to the injectors. You can get the rocker assembly for like $150 from tousley ford.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 4 Old 12-02-2013, 07:39 AM Thread Starter
live for the now
How much are the tubes and where do I get them?
post #4 of 4 Old 12-02-2013, 07:53 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I am not sure how much they are. I would get everything from tousley ford. They have good prices.
08 F350 cc/sb 4X4
