High Pressure Fule Pump Short (Known Issue) - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-26-2013, 10:17 AM Thread Starter
rimshotwheelie's Avatar
I have the new updated part with the protective covering on the harness... is this able to be done without removing the cab? I would assume yes since its under the turbos per say'ish. Truck is immobile due to this, short blows fuel system and no go. I want to at least get this done so it is drivable then can do the other mods later once my buddy is done with his truck.
6 4L Problems Chaffed Hpfp Wire Photo 2
Thanks! -Travis
(Stupid auto correct on the title, FUEL, sorry)
rimshotwheelie is offline
post #2 of 5 Old 11-26-2013, 10:40 PM
I saw a you tube clip of a guy who changed out Fuel pump,said it can be done but it was a real pain in the ***! There is a three part video on how to pull the cab off but you will need two forklifts . Mine went out last may Im trying to get ford to pay for it! now it needs a fuel pump and all 8 injectors from rust/water in fuel system.
armeloj is offline
The Following User Says Thank You to armeloj For This Useful Post:
GSchretter (11-28-2013)
post #3 of 5 Old 11-28-2013, 05:41 AM
Two fork lifts..
Best idea I've heard in a long time.
Thank you.
GSchretter is offline
post #4 of 5 Old 11-28-2013, 12:22 PM
srjd's Avatar
Quoted: 2 Post(s)
If you do not have a proper lift then take it to someone who does. I couldn't imagine using two fork lifts to lift my cab.
Your hpfp went out last may and still fighting with ford?
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #5 of 5 Old 11-28-2013, 12:24 PM
srjd's Avatar
Quoted: 2 Post(s)
Mine is a 01/07 really hope I don't have to deal with this problem any time soon. Especially cause I had the cab up last summer twice and didn't think to get this updated
srjd is offline
