2008 F250 6.4 Reduced Engine Power - Fuel in Oil - Ford Powerstroke Diesel Forum
post #1 of 2 Old 11-18-2013, 06:12 PM Thread Starter
I have a 2008 F250 with 132,000 miles. I was pulling a load a couple weeks ago and when accelerating to highway speeds it said cleaning exhaust filter, made a knocking noise (from the motor I think) and then went into reduced engine power and wouldn't go over 2000 rpm. I drove it the rest of the way home at about 30 mph with no other problems. Took it to the dealership , they said it was exhaust temp sensor, $300 and was back on the road. It ran fine at all speeds, even with a light load, then had a heavy load on it this weekend and it did the exact same thing. This time dealership says there's fuel in the oil and wants $900 just to pull the valve covers to research it further but no guaranteed fix. I tell them no because at that point I was convinced it was the dpf causing the issue and was planning on learning more about the delete kits. On the way home from the dealership, no load, went to accelerate to highway speeds and it made the same knocking noise and went back to reduced engine power. This time it didn't say anything about cleaning exhaust filter and put out a lot of white smoke. I limped it home from there. So while I was originally wanting to learn more about dpf delete kits now I'm wondering if there is another problem. Any advice would be appreciated. Do I have to take this thing to Ford or would other repair shops be capable of properly diagnosing?(not that I believe that Ford is even capable)
jasong65 is offline
post #2 of 2 Old 11-19-2013, 11:03 AM
sschefer's Avatar
It has been my experience with diesels over the years is that they all make some oil over a given period time. I'd have to say that Fords response to the second failure was a way of saying "we don't have a clue at this point".
I personally didn't buy my truck to become and experienced for diesel mechanic. I let them know that today as my truck crossed over that magic 30 or more days in the shop number.
I have the extended warranty on my truck and they told me today that depending on their findings they may need to have an insurance adjuster come out and o.k. the repairs. In the same breath they said they were currently backlogged with diesel truck repairs. That later I have been told every time I've had to take the truck in. To me that seems like a poor business plan.
Would I recommend taking it to a reputable shop other than a Ford dealership. Hard to say, I would have to think that Ford sees more problems with their trucks than anyone else and would have access to far larger knowledge base than any independent shop. I think that's going to be a decision only you can make.
Steve Schefer
Santa Rosa, Ca
08' F350 Super Duty 4x4 OffRoad. 6.4l, Fabtech 6" lift, Procomp 20" wheels/Toyo 37's, K&N Intake. 9" total over stock lift.
sschefer is offline
