2008 F350 6.4 L motor rough idle. - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-18-2013, 08:20 AM Thread Starter
sschefer's Avatar
Saturday, the engine threw a code and lit the check engine light. It acted like it was stuck in overdrive during acceleration.\
Sunday, I start the truck and it starts fine but after maybe 30 seconds there is a definite click and the engine acts like it's missing badly.
I put it in gear and then back in park and RPMS went briefly to 1800 and then back to a rough idle.
I turned the ignition off and then re-started and the idle was normal (check engine light still on). I put it in gear and back in park and it was fine. I drove it and the throttle seemed really sensitive or possibly very short hesitations.
The problem will repeat itself when the engine is started again cold.
The truck is scheduled to go in to the dealer tomorrow. I'm hoping someone knows this symptom so I can know it the dealer has it correctly diagnosed or not. They've missed in the past but have always taken care of it so I'm really more concerned about my down time.
Steve Schefer
Santa Rosa, Ca
08' F350 Super Duty 4x4 OffRoad. 6.4l, Fabtech 6" lift, Procomp 20" wheels/Toyo 37's, K&N Intake. 9" total over stock lift.
sschefer is offline
post #2 of 10 Old 11-18-2013, 09:25 AM Thread Starter
sschefer's Avatar
Tried it again this morning and it repeated. I took it around the block and noticed that I was not showing any boost on the gauge but I could hear the turbo whine. I gave it a short goose and it made a racket under the hood and still no boost. If I accelerate lightly runs o.k. but not right.
Steve Schefer
Santa Rosa, Ca
sschefer is offline
post #3 of 10 Old 11-18-2013, 09:34 AM Thread Starter
sschefer's Avatar
Just did some checking and realized that most of the symptoms are typical of a DPF failure. Any thoughts?
Steve Schefer
Santa Rosa, Ca
sschefer is offline
post #4 of 10 Old 11-18-2013, 11:04 AM Thread Starter
sschefer's Avatar
Just changed the fuel filters but no change in symptoms. This was just to eliminate the dealer saying this was the problem and charging me 300.00 when I can do it myself for 60.00. It only took 4 key on, crank, sequences to fire back up so I seriously doubt it's an injector issue. Still at zero boost. The needle doesn't even twitch but I can hear it spin up and back down. In the old day's I'd say the waste gate was wide open. Not sure what to say to this though.
Steve Schefer
Santa Rosa, Ca
sschefer is offline
post #5 of 10 Old 11-18-2013, 12:54 PM
TD-5's Avatar
Quoted: 3 Post(s)
What code # did it throw?. No boost could be many things. You could check the MAP sensor & see if its plugged, but getting the fault code first will point you in the right direction before tearing into things unnessasarily.
Name:	map sensor2 (Small).jpg
ID:	200234   Click image for larger version
Name:	map sensor port 2 (Small).jpg
2010 F350 KR CCLB, mini max, H&S pyro kit, ARP studs, II 71/59 billet turbos, RCD ported intake, ceramic BD 6.0 exh manifolds, stainless uppipes, SDP 4" ceramic downpipe, 5" MBRP stainless, sinister egr delete with intake elbow, 3" CAC cold side pipe, BD boots, AFE custom air intake, AirdogII, Mann&Hummel CCV filter, 4.10 Yukon locker rear, Eaton TrueTrac front, Coolant filter
TD-5 is offline
post #6 of 10 Old 11-18-2013, 05:55 PM Thread Starter
sschefer's Avatar
I don't have a clue what the code it is that it threw. I don't have the equip to read it. I'm not intending to tear into it, It's going into the dealer first thing tomorrow morning. I have the full extended warranty on the truck so as long as its a component failure it just cost me a 100.00 bill. If it was something like a filter then I'd have to pay for that. The reason I changed it out was because it was time to change it and I didn't want them changing it and charging me shop prices to do something that I could easily do myself.
Steve Schefer
Santa Rosa, Ca
sschefer is offline
post #7 of 10 Old 11-19-2013, 11:16 AM Thread Starter
sschefer's Avatar
I took the truck in this morning. It took three start and shutdowns to get it to run well enough to limp it to the dealer. I got the same old story of them being backlogged with diesel repairs and I might not get the truck back until next week.
They then informed me of the potential costs and I informed them of my standard labor rate and that without the truck I would be billing them for lost revenue. To that they responded that I was eligible for 5 days of rental vehicle up to 35.00 per day. I told them that would be fine but I'd need a truck that can pull a 4000 lb boat because I am a fishing guide. To that they said that none of their trucks have tow packages nor does the rental company that they deal with.
I said, I understand and left it at that. This person was working the service desk and is not responsible for company policy so it's not his fault and he didn't deserve to receive the wrath of my anger. I'll take the issue to upper management.
As a side note: The truck has spent well beyond 30 days in the shop since I've owned it. Will this effect my buying decision when I replace this truck. Yes, most definitely and not positively.
Steve Schefer
Santa Rosa, Ca
sschefer is offline
post #8 of 10 Old 11-19-2013, 06:41 PM Thread Starter
sschefer's Avatar
Dealer Service Manager called me and said they think the problem is a failed Exhaust Back Pressure Sensor. The part isn't in stock but will be here tomorrow and they will replace it and see if it fixes the problem.
Not being trained on these motors I can see some logic to it. If there isn't a reliable back pressure indication then it would make sense that the turbo would not be allowed to provide boost. What bothers me is that if the sensor went bad did it fail on it's own or was there something else that caused it to fail. I have a strange feeling that this may lead to a DPF replacement.
Steve Schefer
Santa Rosa, Ca
sschefer is offline
post #9 of 10 Old 11-20-2013, 10:42 AM Thread Starter
sschefer's Avatar
Dealer just called and said my truck is ready for pickup. Looks like it was just the Back Pressure Sensor after all.
This problem is now resolved. Hopefully some one can reference it in the future and do their own repairs.
Steve Schefer
Santa Rosa, Ca
sschefer is offline
post #10 of 10 Old 11-20-2013, 01:08 PM Thread Starter
sschefer's Avatar
Summary from Ford
Codes Found: P0193, P0642, P1335 and P0069. Found that all codes were related to the VREF Circuit and that they all share monitored PID's for EGR, MAP, BARO, EBP, VREF and VPOWER. Found VREF shorted.
Started unplugging components for the PIDS being monitored and found that when the EBP sensor was unplugged the concern went a way. When plugged back in the concerns came back.
Replaced internally shorted EBP sensor, cleared codes and retest. All Pass.
Steve Schefer
Santa Rosa, Ca
sschefer is offline
