Up pipe removal advice - Ford Powerstroke Diesel Forum
post #1 of 9 Old 11-17-2013, 03:53 AM Thread Starter
Long story short I went to change the egr temp sensor in the passenger up pipe on my friends 08 6.4 and the sensor broke off in the bung. Trying to extract it in the vehicle doesn't seem very easy.
I'd like to remove the pipe but can it be done without cab or trans removal?
Any tips/tricks apreciated!
2001 F250 PSD - Oxford white, Swamps 175/146 Single Shots, intank mods, riff raff rfx ,magnaflow muffler
2001 Lightning - Oxford white, garage queen
DieselSVT is offline
post #2 of 9 Old 11-17-2013, 09:34 AM
Does the truck have an EGR? If not, you can cut the pipe out and relocate the sensor.
B. Adams is offline
post #3 of 9 Old 11-17-2013, 12:51 PM Thread Starter
Yeah it has egr... totally stock truck. Regardless the way the sensor is now it will leak exhaust so I have no choice but to address the old one first. Thx for the reply.
post #4 of 9 Old 11-17-2013, 01:17 PM
Big_Smokey's Avatar
Quoted: 9 Post(s)
If it was deleted you can relocate it and get rid of that pipe. You can really only do a new uppipe. That's a cab off job or drop the tranny.
Search for sensor relocation and egr uppipe removal. I have a thread on it with the help of Bryan.
Big_Smokey is offline
post #5 of 9 Old 11-18-2013, 06:53 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
That wont work for what he is talking about. The sensor he broke off is in the passenger side up pipe. Its the one that reads the egt's. The sensor you guys relocated is the EBP sensor. That is the one in the egr crossover pipe. Even if his egr was deleted you can not get rid of the passenger side up pipe.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #6 of 9 Old 11-18-2013, 07:07 AM Thread Starter
Fatboy...you got it
post #7 of 9 Old 11-18-2013, 07:16 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Originally Posted by DieselSVT View Post
Fatboy...you got it
Honestly bud I am not sure if you can take that pipe off without removing the cab or transmission. If possible I would imagine its extremely difficult. Let us know what you do
08 F350 cc/sb 4X4
post #8 of 9 Old 11-19-2013, 01:37 PM
sschefer's Avatar
Tranny is quicker.
Steve Schefer
Santa Rosa, Ca
08' F350 Super Duty 4x4 OffRoad. 6.4l, Fabtech 6" lift, Procomp 20" wheels/Toyo 37's, K&N Intake. 9" total over stock lift.
sschefer is offline
post #9 of 9 Old 11-21-2013, 06:32 AM
StrokiNDieseL's Avatar
Useful? driver side up pipe cracked
08 F250 6.4L
CcSb Lariat 3.73
5200lbs springs, rear blocks removed, Nitto Grapplers
aFe Mag Force II Si pro 5R w/modded box
H&S MiniMax/Mcc & Gearhead tunes w/Blendmount
aFe Mach Force XP 4" Exhaust w/downpipe
Custom-Diesel Deleted, H&s wastegate w/Intake Elbow & CAC pipe, MPD Ccv/Oil fill mod, Alradco intercooler,
SD Coolant filtration/ CAT ELC...
StrokiNDieseL is offline
