P2452 Help - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-11-2013, 07:46 PM Thread Starter
P2452 Help
Ok,
I will try to explain and hopefully one or several of you smarter people can give me some advice.
Today I had to replace my EGR and housing. I am not mechanically inclined so the ford dealer did it which ran me $1300
The truck drove fine today but not as powerful as it used to be.
I am running an AFE CAI
Spartan tune ( I believe the 175)
4" straight pipe from down tube back.
I drove about 35 miles today and on my way home the CEL came on. Pulled into the drive and read the code P2452.
Why would this happen?
and
How do I fix it.
So, this is what I am thinking, clear the code and reload the tune
or
just clear the code.
But that still doesn't explain the lack of performance.
Thank you for any advice
azrod68 is offline
post #2 of 3 Old 11-12-2013, 12:23 PM Thread Starter
Update
So,
This might help someone else that has an issue with this code. Today I drove the truck with CEL on at first no issues but once the motor warmed up. I drove about 10 miles in the city lots of stop and go. I noticed it was blowing a lot of white smoke. I mean a lot. Pulled over at the park and let the dog run 20-30 minutes. Fired the truck back up and 5 minutes of driving it started smoking again. At idle and under load. I also notice I was using a lot of fuel. I could almost see the fuel gauge go down as long as the truck was running. Drove to locale dealership and talked with them. I have an appointment with them in the morning and they will take a look. I brought the truck home. It drives fine, didn't go into limp mode just blows a ton of white smoke, and using a lot of fuel. Almost like the vehicle was going into regen mode. Came home reloaded my tune, the code is gone and no more white smoke. Truck feels like more power. I will do a longer drive and give you guys an update.
I am looking for any advice or concerns I should have with this.
Thank you for any help or advice
azrod68 is offline
post #3 of 3 Old 11-16-2013, 03:19 AM
I would think you might need to reload your tune. You shouldn't get that code with your tune.
Ambulance39 is offline
