2008 doesnt stay warm - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-07-2013, 02:47 PM Thread Starter
2008 with a spartan tuner, lower hp setting, dpf, egr delete. The engine temp gauge never goes past 1/4. On a warm day it'll go near halfway while driving, but then when you idle, it will drop back down. Can this be a stuck open thermostat? Now that the colder months are here, it struggles to get warm. other than that, it drives absolutely perfect.
2008 F450 w/Century 311. DPF/EGR delete. Spartan tuned.
2003 Grand Marquis..some mods...
jasong145 is offline
post #2 of 5 Old 11-07-2013, 04:40 PM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
Sounds like a stuck thermostat, can you monitor actual ECT via the obd2 port to verify it's not just a bad sending unit to the gage
Sent from AutoGuide.com App
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #3 of 5 Old 11-11-2013, 10:59 AM
similar problem
Mine ('08 w/spartan) comes up to temp fine however the heater goes "in and out". As in, fan blows warm then cold air back and forth while driving. Had new rad, water pump annd fan assy put in last summer. fluids topped off. however this problem has existed for a couple winters. i live with it, but wifey driving it now so.....i don't to give her an excuse to be any more cold than normal...LOL!!!
has pushed coolant in the past.
underpressure910 is offline
post #4 of 5 Old 11-11-2013, 11:20 AM
Winning DUHHH
Quoted: 8 Post(s)
Yikes! Time for studs and head gaskets
6637
Wicked Wheel'd,
Southbend
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
Dont Tread on Me
post #5 of 5 Old 11-11-2013, 11:37 AM
underpressure910: Sounds more like air in the coolant system to me. Maybe it's that cavitation thing I have heard of, but never saw, but I would drain and refill the coolant. Check your oil to make certain it's good.
jasong145: Stuck thermostat, or faulty sensor.
Tommycat is offline
