08 6.4 Smell coolant please help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-04-2013, 08:21 AM Thread Starter
I have an 08 350 with an H&S mini max, DPF Delete, intercooler pipe upgrade. Yesterday when pulling into the yard I smelled coolant, checked for leaks can not see anything. There was no coolant in the oil thank goodness. Could this be an issue with the EGR cooler I have not done a delete?
Thanks
country41 is offline
post #2 of 8 Old 11-06-2013, 06:24 AM
Hey country I would say call your local parts store auto zone advanced what have you. And see if any of them have a pressure tester for your truck that way you can pressurize the system might be able to find the leak then. Also check on youtube there are several videos that show you the common leak spots for our trucks. I actually just found a leak near my front cover so Ill be pressure testing mine today as well. I want to make sure it's just a front cover seal not cavitation but any way hope that helps.
2008 F-350 Lariat TRCCSB Lifted, Tuned, and Deleted
2003 Mach1 Bassani, 4.10s, pro5.0, bama tuned
thnderchcken is offline
post #3 of 8 Old 11-06-2013, 06:29 AM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 7 Post(s)
Feedback Score: 12 reviews
Also- many people including myself over filled the coolant tank. I found that I had to keep it filled about 2 inches below the minimum level to keep it from burping coolant. Not sure if yours is burping a little bit or not but that's possible.
Sent from AutoGuide.com App
Marshall
2002 F250 7.3L CCSB 4WD
Tinted | Focal speakers & 12" Kicker | CTS Insight | CNC fuel line kit | PIS 200/80's | KC38R | Nathan P3 train horns & Onboard Air
mts678 is offline
post #4 of 8 Old 11-06-2013, 09:09 AM Thread Starter
Thanks guys I will try getting the system pressure tested and see if that helps. I just had the radiator replaced about 4000 miles ago it had cracked one of the plastic corners.
post #5 of 8 Old 11-07-2013, 12:45 AM
srjd's Avatar
Quoted: 2 Post(s)
If I kept my degas bottle 2 inches below the cold line is still be driving around with blown head gaskets.
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #6 of 8 Old 11-07-2013, 05:01 AM
mts678's Avatar
Quoted: 7 Post(s)
I'm saying its a possibility as that was the case for me. Not saying that's his problem! Why does everybody have to take comments totally the wrong way on forums these days? It's almost as if people are just looking for a comment to lash out on in some way or another
Marshall
mts678 is offline
post #7 of 8 Old 11-07-2013, 10:06 AM
srjd's Avatar
Quoted: 2 Post(s)
MTS I'm sorry man I honestly didn't mean for it to come across that way. I was just saying my experience to give him other sceneries. Reading it again I see how it could have come across that way. I apologize. I do agree with you that some people are looking to lash out any chance they get. Anyways have a good day
srjd is offline
post #8 of 8 Old 11-07-2013, 10:16 AM
mts678's Avatar
Quoted: 7 Post(s)
Thanks for clearing that up man, I think we've been in a few other threads before and there wasn't any animosity then so I was like man, what's his deal lol. I appreciate it!
Marshall
mts678 is offline
