Oil light on when re-starting truck - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-31-2013, 01:09 PM Thread Starter
soundmandave21's Avatar
Exclamation Oil light on when re-starting truck
So, if I shut the truck down and let it sit for a short period of time, the oil light comes on for a second (or less) and then shuts off. The light does not stay on, but it has recently started doing this EVERY time I re-start the engine after it has been warmed up. Has anyone else had this issue, and figured out what the cause is? I REALLY don't want to have to pull the engine and do an oil pump or a worse, a rebuild...
1997 4x4 F-250 Xcab LB, ChildSeat
soundmandave21 is offline
post #2 of 6 Old 10-31-2013, 05:11 PM
Oil pump is done engine in, it's at the front of the crankshaft behind the balancer. You do need special toolsl for the crank seal. I'd try a oil pressure regulator first (or just stretch the spring / add washers). From underneath, it's behind / below the balancer. Uses a 12mm Allen key I think. Make sure you get 3 things or of the hole. The cap, the spring and the plunger.
Hauser is offline
post #3 of 6 Old 11-01-2013, 11:54 AM
Combs19's Avatar
Mine has been doing the same thing since I owned it with only 17,000 miles on it. I've got 35,000 miles on it now with no problems. So what is going to happen if I do nothing?
2008 F350 Crew Cab Harley Davidson
Early 99 (converted to Late 99) Sold!!!
F250 Crew Cab short box
Mods: S&B Intake, H&S Tuner, Delete Pipe, Newton 2 1/2" Leveling Kit with 5.5" traction bar blocks, 305/60R20 Goodyear Silent Armor Tires on Stock Harley Rims.
Combs19 is offline
post #4 of 6 Old 11-01-2013, 12:13 PM Thread Starter
I spoke with a reputable mechanic here who specializes in Powerstrokes. He said it is not something to worry about. If the light comes on and stays on, then you have a problem. For now I am not going to worry about it...
post #5 of 6 Old 11-01-2013, 12:33 PM
Combs19's Avatar
Thanks. Had someone tell me the same thing.
Combs19 is offline
post #6 of 6 Old 11-02-2013, 06:06 PM
what if it comes on after you turn the engine off but goes away right after you start the engine?
western762 is offline
