oil leak - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-26-2013, 02:06 PM Thread Starter
cbradley's Avatar
oil leak
i had to take this boot or hose whatever it is loose to change out a pully and now i have noticed a oil leak all over that pipe and my air box and hood ! question I have is I don't see any leak why ideal do they leak a fine mist while driving ?
cbradley is offline
post #2 of 4 Old 10-26-2013, 04:43 PM
srjd's Avatar
Quoted: 2 Post(s)
Its from your crank case vent. Search ccv mod and do it cause that vapor mixed with egr is terrible for your truck
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #3 of 4 Old 10-27-2013, 08:53 AM Thread Starter
cbradley's Avatar
Ok where is the ccv at looks like the oil is coming off the bottom of that boot. Also it didn't look as bad after my last 80 mile trip could it be after I put my sct tuner on and deleted dpf it caused the leak under heavy acceleration
cbradley is offline
post #4 of 4 Old 10-27-2013, 09:06 AM
srjd's Avatar
Quoted: 2 Post(s)
If it is the ccv its not a leak and tuner won't effect it. Its just vapor from the crank case. If you look from the oil fill cap there is a hose going from there to your intake just after the air filter. Just look up ccv mod like I said that will answer your questions
srjd is offline
