P0528 and P0480 Codes and mystery plugs - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-25-2013, 04:54 AM Thread Starter
barlowchiro's Avatar
My check engine light isn't on, but I ran the diagnostics the other day and these two codes popped up. The truck isn't running hot, it averages around 195ish with normal driving.
I recently had the belt replaced and thought maybe they didn't plug the fan clutch wiring harness back in, so I thought I would check that first.
Where can I find that plug?
Also, what are these three plugs for? My (non-existant) EGR cooler??
2008 SB CC KR 6.4L Job 1
AFE CAI
EGR Delete
5" DPF Delete
4" DP
MBRP Passenger Side IC Pipe
H&S Mini MAXX
2.5" Ready Lift Leveling Kit
35x12.5x20 Toyo Open Country MTs w/ stock KR wheels
AMP Research Power Steps
Coming Soon: CCV Mod, Air Dog II
barlowchiro is offline
post #2 of 7 Old 10-25-2013, 10:45 AM
srjd's Avatar
Quoted: 2 Post(s)
The plugs at the bottom of your hand are egr. The top long plug is for your fan it needs to be plugged in
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #3 of 7 Old 10-25-2013, 10:54 AM Thread Starter
OK. I thought maybe it was left unplugged!!
So the bottom two are for the EGR, the long one I am holding is for my fan. Where does it plug it at?
AFE CAI
EGR Delete
5" DPF Delete
4" DP
H&S Mini MAXX
post #4 of 7 Old 10-25-2013, 11:09 AM
srjd's Avatar
Quoted: 2 Post(s)
On the back of the fan shroud. The plastic piece that says power stroke when you open your hood
srjd is offline
post #5 of 7 Old 10-25-2013, 11:50 AM Thread Starter
Ok. I found the hole in the center of the fan shroud where it plugs in, but the other end of the plug isn't in there! I looked down around the fan to see if maybe it fell down in there, but I can't see it anywhere.
Where does it run from?
AFE CAI
EGR Delete
5" DPF Delete
4" DP
H&S Mini MAXX
post #6 of 7 Old 10-26-2013, 10:53 AM Thread Starter
Is there any reason that anyone would do away with the plug at the top back of the fan shroud? I can't find it anywhere, I crawled under the truck, on top of the engine, I just can't find that plug anywhere?
Does anyone know where it originates from?
AFE CAI
EGR Delete
5" DPF Delete
4" DP
H&S Mini MAXX
post #7 of 7 Old 10-30-2013, 02:24 AM Thread Starter
Got it plugged back in.
Thanks for the help!!!
AFE CAI
EGR Delete
5" DPF Delete
4" DP
H&S Mini MAXX
