Truck squeaks at startup - Ford Powerstroke Diesel Forum
post #1 of 11 Old 10-21-2013, 01:23 AM Thread Starter
WesGee's Avatar
I have an 08 F-250, recently I noticed (not sure how long it's been happening) when I crank my truck up for the first time each day it makes a squeak from under the hood and after running for about 5-10 seconds it'll chirp once more then that's it. I only drive the truck a couple of times each week. It runs fine and once it's been driven a little it won't do it anymore when I crank it up. Problem is I can't duplicate it for the dealer because once I drive it there it won't do it when I crank it. Any ideas?
Sent from AutoGuide.com App
WesGee is offline
post #2 of 11 Old 10-21-2013, 11:32 PM
srjd's Avatar
Quoted: 2 Post(s)
Idler pulley
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #3 of 11 Old 10-22-2013, 06:20 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
^^ this or belt tensioner.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #4 of 11 Old 10-22-2013, 04:24 PM
jaysshortbus's Avatar
Mine would squeak when I shut it off and I replaced the belt and it went away ! After I changed the tensioner and idler pulley as I thought them to b the culprits! ! Get someone to just pour a tiny bit of water on belt while its running and squeaking and if it goes away its your belt ! I found its best to pour it on top of alternator !!
Jay
jaysshortbus is offline
post #5 of 11 Old 10-22-2013, 04:38 PM
Belt slipping.
Probably nothing like mine, but could be early warning sign of something.
GSchretter is offline
post #6 of 11 Old 10-22-2013, 06:10 PM Thread Starter
WesGee's Avatar
Once it's running it stops, it chirps once when I crank it and then a few seconds later it chirps and that's it. It's not continuous.
WesGee is offline
post #7 of 11 Old 10-22-2013, 06:11 PM Thread Starter
WesGee's Avatar
Still have a warranty I guess I'll just have to drop it off. Thanks for all the suggestions.
WesGee is offline
post #8 of 11 Old 10-22-2013, 06:14 PM
srjd's Avatar
Quoted: 2 Post(s)
The answer was all ready given to you its a very common problem. Its belt tension or and or idler pulley
srjd is offline
post #9 of 11 Old 10-22-2013, 06:16 PM Thread Starter
WesGee's Avatar
Thank you. I really appreciate it.
WesGee is offline
post #10 of 11 Old 10-22-2013, 06:17 PM
Thats what I was told too ended up being the belt !
Jay
