Turbos Bad???? - Ford Powerstroke Diesel Forum
post #1 of 28 Old 10-18-2013, 10:35 AM Thread Starter
barlowchiro's Avatar
Turbos Bad????
Alright, intercooler pipe was taken off for a belt change. Sludge with the consistency of tapioca pudding was in the intercooler pipe, is this bad turbos? It seems to spool up just fine, no smoke (that I can tell) coming from the exhause. May be loosing just a slight amount of coolant (possibly 1" down in the reservoir) but may be not. My boost is acting normal for day to day driving. I never get on it and have my boost defuel at 26psi.
If it is turbos, I am thinking of getting a used set off of a 2010 w/23K miles.
2008 SB CC KR 6.4L Job 1
AFE CAI
EGR Delete
5" DPF Delete
4" DP
MBRP Passenger Side IC Pipe
H&S Mini MAXX
2.5" Ready Lift Leveling Kit
35x12.5x20 Toyo Open Country MTs w/ stock KR wheels
AMP Research Power Steps
Coming Soon: CCV Mod, Air Dog II
barlowchiro is offline
post #2 of 28 Old 10-18-2013, 11:46 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Nope that is normal. Its oil from the CCV. The only way to take care of it is do a ccv mod (either to the atmosphere or to a catch can).
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 28 Old 10-18-2013, 11:49 AM
srjd's Avatar
Quoted: 2 Post(s)
Do you have a pic. Could just be from your ccv and egr unless its real bad. I had my turbos replaced when they did my head gaskets at ford. Said they were leaking internally they felt fine to me. Still think I got ripped off
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #4 of 28 Old 10-18-2013, 01:14 PM Thread Starter
I don't know how much was in there, my mechanic told me about it. I wish I would have had him take a picture of it.
Is there any way to check the turbos? Like I said no smoke out of the exhaust or anything.
AFE CAI
EGR Delete
5" DPF Delete
4" DP
H&S Mini MAXX
post #5 of 28 Old 10-18-2013, 03:47 PM
Big_Smokey's Avatar
Quoted: 8 Post(s)
26lbs is your defuel! geesh i hit that leaving the driveway!
Big_Smokey is offline
post #6 of 28 Old 10-30-2013, 03:26 AM Thread Starter
Went back to mechanic today, because of the hissing/air leak sound. It is coming from my turbos. He pulled the cold side intercooler pipe and the antifreeze was definitely in there. I guess that means new turbos for me
AFE CAI
EGR Delete
5" DPF Delete
4" DP
H&S Mini MAXX
post #7 of 28 Old 10-30-2013, 01:38 PM Thread Starter
Can anyone come up with a reason there would be some coolant in my cold side IC pipe????
AFE CAI
EGR Delete
5" DPF Delete
4" DP
H&S Mini MAXX
post #8 of 28 Old 10-30-2013, 01:45 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I cant. Oil is normal in the cold side pipe. I have no idea how coolant would get there. I would make sure your turbos are bad before you replace them.
08 F350 cc/sb 4X4
post #9 of 28 Old 10-30-2013, 01:52 PM Thread Starter
I agree!!! I am pretty sure the up pipe needs replaced, that alone is $2300 at the dealer. I really don't want to spend another $3000 to replace turbos that don't need it.
How can I tell if they are bad????
AFE CAI
EGR Delete
5" DPF Delete
4" DP
H&S Mini MAXX
post #10 of 28 Old 10-30-2013, 01:55 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Is your boost normal? Are you losing oil thru the tail pipe? Are they making any noise? What is their reasoning telling you that your turbos are bad because you have coolant in the cold side pipe? That doesn't make any sense. Coolant doesn't even run thru the turbos.
08 F350 cc/sb 4X4
