Turbo issue on '08 6.4L - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-07-2013, 01:19 PM Thread Starter
Tyler Williams's Avatar
Appears we have a turbo leak, the Ford dealer claims this is a "normal" problem to occur.
Anyone else witness this? Is it as simple as replacing the necessary gaskets, or does the turbo itself need replacing?
What other "normal" issues shall I expect with this truck in the next little while? I need this thing to stay on the road for the next month, after that I plan to burn it.
It currently has 135,500 kms on it.
Tyler Williams is offline
post #2 of 5 Old 10-23-2013, 03:31 PM
I had this situation on my 08 at 90k miles. When we got in there the #1 turbo was shot. Ended up replacing the turbo and all of the gaskets. Runs great now!
BlueF350 is offline
post #3 of 5 Old 10-24-2013, 05:37 AM
barlowchiro's Avatar
How did you know you had a turbo leak?
Could you hear it?
Any loss of power?
Any loss of boost?
2008 SB CC KR 6.4L Job 1
AFE CAI
EGR Delete
5" DPF Delete
4" DP
MBRP Passenger Side IC Pipe
H&S Mini MAXX
2.5" Ready Lift Leveling Kit
35x12.5x20 Toyo Open Country MTs w/ stock KR wheels
AMP Research Power Steps
Coming Soon: CCV Mod, Air Dog II
barlowchiro is offline
post #4 of 5 Old 10-24-2013, 08:05 AM Thread Starter
The Y pipe was the fault, this is what they claimed as a "normal" issue. Yes it could be heard, no loss of power.
post #5 of 5 Old 10-24-2013, 01:49 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
That's not a turbo issue. leaking up pipes are fairly common on stock and tuned trucks. Has to do with back pressure.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
