Hurt the motor - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-28-2013, 01:01 PM Thread Starter
Hurt the motor
09 6.4
5" db
Egr blocked off
Ran the 275 a while put the 300 on the night before it broke.
Was on it before work, got out of it and it died .... it sounded like a head gasket and didn't blow any glow plugs .. I plan on pulling the cab. I decided to pull the glow plugs and they're covered in oil. Is that normal when you pull them out like the 7.3?
dialedin is offline
post #2 of 10 Old 09-28-2013, 01:24 PM Thread Starter
dialedin is offline
post #3 of 10 Old 09-29-2013, 04:04 AM
Cracked one or more pistons likely.
SOOTIE is offline
post #4 of 10 Old 09-29-2013, 07:42 AM
Powerstroke Techie
That sure isn't a lot of information regarding the failure...
Yes, glow plugs will look like that when you pull them regardless of engine health.
What do you mean 'it died'? Stalled?
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #5 of 10 Old 09-29-2013, 07:50 AM Thread Starter
Yes it stalled . I wasn't really asking for a diagnosis ... thanks, just wondering about the plugs . I know its not that easy .. only thing is it had a external noise like a head gasket
dialedin is offline
post #6 of 10 Old 09-29-2013, 09:21 AM
Powerstroke Techie
Not sure what you mean by external noise?
Typically these engines during a head gasket failure just push compression into the cooling system.
Just trying to save you some work. If it stalled and didn't restart, I'd do a little more digging than condemning the engine right away. Just my .02
post #7 of 10 Old 09-29-2013, 10:44 AM Thread Starter
Went from normal sounding motor , to a loud miss on each rotation like a head gasket or a leaky manifold.
dialedin is offline
post #8 of 10 Old 09-29-2013, 10:49 AM
Compression test first. Start simple before you start ripping things apart.
letitsno is offline
post #9 of 10 Old 09-29-2013, 10:51 AM Thread Starter
That's what I'm doing now .. ripping things apart ? Glow plugs out...
dialedin is offline
post #10 of 10 Old 09-29-2013, 11:26 AM
Ok enjoy & take your time and mark zip lock bags for small parts & bolts.
Takes more time, but makes it easier to put back together.
letitsno is offline
