08 f350 - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-17-2013, 05:04 PM Thread Starter
08 f350
Hi guys. just looking for advice. my truck lately has been getting a wrench light after driving about 40 miles in very hot weather. I have a livewire 9625 xtreme. I haven't tuned truck yet but thought id scan gauges while I went to work in morning and after work. in the morning it was only 10 degrees Celsius and temp deltas were around 8 degrees and no light. two mornings in a row. today with the tuner watching on the way home, I got a wrench light. I was really watching the temps. it was around 27 degrees Celsius, 40 mile drive home. deltas were sitting right around 15 degrees and suddenly out of the blue 90% of the way home, the coolant temp dropped 2 degrees f. and right then the wrench light came on. It was a 17 degree difference. should I be alarmed????
nocturnal30 is offline
post #2 of 4 Old 09-18-2013, 06:24 AM
Quoted: 2 Post(s)
are you running Canned tunes that came with it? or are you running custom tunes from a tuning company?
when you're loading the tunes onto your truck, when the option comes up if you have "disabled the EGR" you should be selecting yes, even if its still on your truck. I ran into this issue when i first installed my livewire. also, oil temp read out is in Celcius if you didn't know that. hope this helps.
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #3 of 4 Old 09-18-2013, 07:23 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Are you talking about the spread between your ECT and EOT? If so that means your oil cooler is getting plugged.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #4 of 4 Old 09-18-2013, 04:24 PM Thread Starter
Yea. Thats what i was talking about. Then today drove same trip home 45 miles but in 15 degree celsius weather and no light. Only when its really hot out
