Please help 6.4 blows blue smoke!!! - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-12-2013, 02:54 PM Thread Starter
i have an 08 f350 mods done are: H&S mini max, AFE 5" exhaust with downpipe and dpf delete, sinister full egr delete, air raid cold air intake. When i drive the truck nicely i dont have any issue but if i give it hard throttle once i stop at an intersection or if its under load blue smoke billows out the tailpipe....if i rev it in park it gives one big puff hard to tell if white or blue at that point and then goes away and comes back slowly. after i drive around normally it slowly goes away till its gone and wont start smoking till i romp on it..any ideas? ive had a compression test done and all cylinders are fine
wrivett is offline
post #2 of 9 Old 09-12-2013, 03:17 PM
I would suspect turbo, seems common with these trucks. You can take off the down pipe and check for oil. It doesn't take long and it's easy to check, first place I'd start. Good luck.
gfaststroker is offline
post #3 of 9 Old 09-12-2013, 03:23 PM Thread Starter
i was thinking that, im not familiar with the twin turbo set up on these trucks, when turbo seals go it usually smokes all the time. tell me if you think this is logical or if im in left field...when im driving around normally my low pressure turbo is doing all the work and when i am hard on the throttle my high pressure spools up and starts taking in oil and when i go back to driving normally it stops leaking?
wrivett is offline
post #4 of 9 Old 09-12-2013, 03:46 PM
Yeah, my brothers truck did the smoke at idle and low rpms and cleared up with boost. He ran it like 20000 miles that way, it never got worse. Finally after running a couple thousand he started seeing oil coming out the tailpipe. Not saying that positively what it is but I would check it out.
post #5 of 9 Old 09-12-2013, 05:25 PM Thread Starter
ok thanks for the help
wrivett is offline
post #6 of 9 Old 09-19-2013, 04:59 AM
I am having a similar problem but about 1/4-1/2 throttle there is a squeal as well any ideas?
08 F-250 Harley Davidson
H&S MiniMaxx
Gearhead performance tune
ARP head studs
Flo~Pro turbo back 5" w/ DPF delete
AFE stage 2 intake
Flo~Pro egr delete w/ cold side pipe
Built trans
JackFrost376 is offline
post #7 of 9 Old 10-05-2013, 09:19 AM
08 f250 just had new engine put in.week later noise comin from fuel cooler .they check it and no coolant in it. they say i need anew one. who pays
archie53 is offline
post #8 of 9 Old 10-05-2013, 09:21 AM
any help on this
archie53 is offline
post #9 of 9 Old 10-17-2013, 09:38 PM
deamsphelps's Avatar
I'd say you might get a better chance at an answer if you start a new thread.
deamsphelps is offline
