Water pouring to the ground when A/C is on - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-02-2013, 06:34 PM Thread Starter
Down2Ride's Avatar
Tons of water leaking to the ground when a/c is on. Truck has been sitting for a few months being cranked every few days. Cleaning it up today and noticed a huge amount of water hitting the ground while idling in the drive. I know it should drip some, but there is a river flowing down the driveway. Water coming from hole in firewall on passenger side. What could be the problem? Air blows cold, but leaks tons of water on the ground.
'08 F250 Crew Cab King Ranch 6.4L (White)
4" Zone Offroad Lift
Spartan Tuned
Spartan TCM
DPF/CAT Delete
EGR Delete
ARP Head Studs
S&B
MBRP
35x12.50x22 TOYO M/T
Down2Ride is offline
post #2 of 10 Old 09-02-2013, 06:47 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Do you live in a high humidity area? Has it been raining? I wouldn't stress out too much. As long as its just water from the condenser and not any oil or anything its just the ac getting cold. Im sure one of the hvac tech's will be along soon to give you the Bill Nye the science guy version of what is going on......
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 10 Old 09-02-2013, 06:52 PM Thread Starter
Down2Ride's Avatar
Ok. Just making sure. Thanks
Spartan Tuned
Spartan TCM
DPF/CAT Delete
EGR Delete
ARP Head Studs
S&B
MBRP
post #4 of 10 Old 09-02-2013, 06:55 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Its not comin into the truck is it?
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 10 Old 09-02-2013, 07:08 PM Thread Starter
Down2Ride's Avatar
Nope. Just behind front tire on passenger side. A lot.
Spartan Tuned
Spartan TCM
DPF/CAT Delete
EGR Delete
ARP Head Studs
S&B
MBRP
post #6 of 10 Old 09-02-2013, 07:12 PM Thread Starter
Down2Ride's Avatar
Was kind of warm/ humid today. In northwest TN right now.
Spartan Tuned
Spartan TCM
DPF/CAT Delete
EGR Delete
ARP Head Studs
S&B
MBRP
post #7 of 10 Old 09-02-2013, 07:12 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Ya as long as your sure its just water I wouldn't sweat it. That being said I still get that drop feeling in my gut when I walk out and see water pouring from my truck....
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #8 of 10 Old 09-02-2013, 07:16 PM Thread Starter
Down2Ride's Avatar
Yeah. Not a good feeling. The liquid is clear, no smell, doesn't feel oily to touch.
Spartan Tuned
Spartan TCM
DPF/CAT Delete
EGR Delete
ARP Head Studs
S&B
MBRP
post #9 of 10 Old 09-03-2013, 03:22 AM
I'm in va - mine flows a river as well but remember, they are big cabs with big units in them and will create a lot of condensation....
seafordguy is offline
post #10 of 10 Old 09-04-2013, 02:54 PM
pops250's Avatar
SC here its humid enough to ring water out of the air and mine pours water out also.
H&S tuned. B&W gooseneck hitch with Companion 5th wheel. Helwig rear sway bar. Edge CTS monitor. Dieselsite coolant filter. Rancho 9000 shocks. Airlift 5000 air bags with onboard compressor. Viair onboard air with 5 gal tank. Flo-pro stainless 4 in. exhaust.
pops250 is offline
