Turbo Whine? Turbo Leak? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-20-2013, 09:26 AM Thread Starter
This truck is my first diesel and first turbo, so it's all new to me.
Truck: 2008 F350 4x4 CCLB, 6.4, stock (no aftermarket upgrades), 47k miles
I tow a 9k lb travel trailer once or twice a month on average and I have noticed this on my last 4 tows. On long hill climbs, the boost will go over 30 PSI and if I keep it there, I will almost always get a whine type sound that corresponds with the boost (if the boost decreases, the whine decreases; if the boost increases, the whine increases). I do not get the whine unloaded, only when towing the trailer.
Any ideas? Could it be a turbo leak? Where would I look?
I bought the truck in September. The truck was in the shop for service in January due to a bed plate oil leak and they did remove the cab to fix.
2008 F350 4x4 6.4l CCLB w/ canopy
mattyk6 is offline
post #2 of 7 Old 08-20-2013, 01:59 PM
fiderius22's Avatar
Sounds like you're just not used to hearing the real whistle of a spoiled turbo.
Sent from AutoGuide.com App
08 6.4 F-250
ARP studs
Rudy's coated/machined pistons
CX Aluminum intercooler
No Limit ic pipes
ccv Reroute
AFE MF intake
PTP EGR delete w/ elbow
Diamond Eye 5" dp back with MBRP 7" tip
H&S Mini HD300
PATC triple disc billet tc
PATC stage 3 built trans
6" 4-link rough country lift
PMF stage 2 trac bars with gussets and block mount
20x10 XD Revolvers with Federal 35 MTs
Advantage Max-4 wrapped bumpers/grille
Reflexxions steel cowled hood
5% tint
Kenwood nav/dvd
fiderius22 is offline
post #3 of 7 Old 08-20-2013, 02:00 PM
fiderius22's Avatar
Spooled sorry, damn auto correct!
08 6.4 F-250
ARP studs
No Limit ic pipes
ccv Reroute
AFE MF intake
H&S Mini HD300
5% tint
Kenwood nav/dvd
post #4 of 7 Old 09-05-2013, 12:51 PM
Is it a whine sound or a whistle sound? Mine will make a whistle sound when I tow my trailer at about 25 psi and above.
Hinesks is offline
post #5 of 7 Old 09-09-2013, 08:44 PM Thread Starter
I hope its normal. I haven't noticed anything odd.
Its not really a whistle, more like blender or vacuum cleaner. I know, not very descriptive.
mattyk6 is offline
post #6 of 7 Old 09-30-2013, 04:55 AM
Turbo whine.
I also have a 2008 F350 6.4, and it whines when my turbo spools to 25-30psi. However, I do have a tuner and a few other mods on it. My turbo will whine even when its not under a load. Its in the shop now, so hopefully this will be in the past soon.
TravelnTexn is offline
post #7 of 7 Old 09-30-2013, 06:23 AM
srjd's Avatar
Quoted: 2 Post(s)
Check for soot on the firewall near the turbo and up pipes. Could have a cracked up.pipe
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
