quiet rattle - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-19-2013, 05:46 AM Thread Starter
quiet rattle
when i pull away in my 2010 superduty i hear a quiet chattering rattling kinda noise. truck runs perfectly. Can anyone help with this.
drubhan is offline
post #2 of 9 Old 08-19-2013, 07:45 AM
Exhaust possibly. Is it a clanky metallic sound or a squeaky rattle like your tailgate?
Expirobo is offline
post #3 of 9 Old 08-19-2013, 08:09 AM Thread Starter
rattle
rattle, tapping sound that is metalic and raises with the revs
drubhan is offline
post #4 of 9 Old 08-19-2013, 08:11 AM
does it sound like it could be sway bar links? or some other suspension rattle. check your links and body mounts for play.
kmack08 is offline
post #5 of 9 Old 08-19-2013, 08:19 AM Thread Starter
it raises with the revs of the engine
drubhan is offline
post #6 of 9 Old 08-19-2013, 08:46 AM
My first GUESS would be the belt tensioner. They kind of separate when they go bad. As you rev, the tensioner will spin slightly.
My second GUESS would be a broken/bent pushrod, lifter, or rocker.
Also, check the exhaust and listen around the turbo.
Best way to diagnose is to get a friend/wife/etc and have them lightly rev while you track down the location of the rattle. Might need to lay underneath it.
Expirobo is offline
post #7 of 9 Old 08-19-2013, 09:08 AM
0864stroker's Avatar
I am having about the same issue. It seems louder before my truck gets to operating temp then almost disappears. When it is idling you can hear it the most near the driver's side wheel well or underneath. It sounds like a metallic rattle possibly somewhere near the egr cooler. My truck was parked for 2 weeks, grill being painted, and started doing this when I started it, never heard it before.
http://youtu.be/QHZ7-SXk06A
'08 F-250 Lariat
SCSB 4X4
BF Goodrich Rugged Terrain T/A
H&S Mini Maxx
Flo-Pro 5" DP Back
20% Window Tint
Recon Smoked Cab & Mirror Lenses
0864stroker is offline
post #8 of 9 Old 08-20-2013, 02:03 PM
fiderius22's Avatar
Ok this might sound crazy but I had a weird chatter for awhile. Finally found the ebp pipe was shaking against the up pipe. Welded a small bracket between them and instant fix. I'm egr deleted though.
Sent from AutoGuide.com App
08 6.4 F-250
ARP studs
Rudy's coated/machined pistons
CX Aluminum intercooler
No Limit ic pipes
ccv Reroute
AFE MF intake
PTP EGR delete w/ elbow
Diamond Eye 5" dp back with MBRP 7" tip
H&S Mini HD300
PATC triple disc billet tc
PATC stage 3 built trans
6" 4-link rough country lift
PMF stage 2 trac bars with gussets and block mount
20x10 XD Revolvers with Federal 35 MTs
Advantage Max-4 wrapped bumpers/grille
Reflexxions steel cowled hood
5% tint
Kenwood nav/dvd
fiderius22 is offline
post #9 of 9 Old 09-07-2013, 05:34 PM
sounds like the infamous 'tick' that ford deems normal....did a lot of research, thought mine had injector cackle, rod bearings, rocker issues. so far driven many miles and not found my issues yet, dealer always said normal..i say bull poop...but start by the injectors, turn them off one at a time (ids)..will give some direction
let us know what you find...
toddster is offline
