Mysterious oil spray help! - Ford Powerstroke Diesel Forum
post #1 of 8 Old 08-14-2013, 06:11 PM Thread Starter
I have a oil leak on my passenger side, and it sprays the whole right side of my truck. It's not glow plug Harness because I just replaced that. What could make it have enough pressure to spray that far?
ColtonH00 is offline
post #2 of 8 Old 08-15-2013, 07:10 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
A cracked piston can cause that much pressure
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 8 Old 08-15-2013, 07:37 AM
Blue Goose's Avatar
......and it will blow it out of the dipstick tube. Have you checked for blowby?
06 KR 250
Blue Goose is offline
post #4 of 8 Old 08-15-2013, 08:31 AM
Could be a drip somewhere up front that catches the wind or the air from the fan and blows it around. Have you looked in there with a flashlight to try to locate the source of the leak? Might want to wait 'till she's cold and clean up the engine compartment. Then, after it's dry, fire it up and start leak checking.
Expirobo is offline
post #5 of 8 Old 08-15-2013, 04:58 PM Thread Starter
Blow bye is all good, and nothing's coming outta the dipstick. Do these motors have an oil drain tube? I'm starting to think that one of my fuel lines is leaking and overflowing my oil. I'm pretty sure I have a fuel leak because I filled my rig up and it was all gone in two days, I maybe drove 100 miles..
post #6 of 8 Old 08-15-2013, 07:05 PM
Uh??? Yeah dude, unless you're getting 3 mpg, that would be a SERIOUS problem. Have you thought about checking your oil level?
If I were you, I would take it in and have it checked out. Obviously something is wrong.
Expirobo is offline
post #7 of 8 Old 08-15-2013, 07:19 PM
Also, what do you mean by "oil drain tube"? There are roughly three places a person should access the oil:
1. Oil fill tube.
2. Dipstick
3. Oil drain plug.
Expirobo is offline
post #8 of 8 Old 08-15-2013, 10:20 PM Thread Starter
It's leaking faster than the fuel is poring in. I'm going to replace those lines, try to find the leak, and then change the oil
Tags
leak , oil , powrstroke , pressure , spray
