6.4 egt / power issue - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-04-2013, 12:46 PM Thread Starter
Bad Night's Avatar
Quoted: 5 Post(s)
On my 08 F-350 I have recently noticed the egt's seem to be higher . Just cruzing along at 45 I am seeing around 375 or so which seems normal . If I touch the throttle at all it climbs very fast . Flooring it from a 45 mph roll it climbs to 1400 in seconds . The truck feels down on power as well . It almost feels like I am pulling a trailer even when not . I have the dpf deleted and am running an h&s mini max with the big power tune in it . I have pulled a light trailer with this and only seem egt's of around 1200 . This just seemed to come on out of no where . I jumped on the throttle earlier and after letting off hear a clicking noise that lasted a few seconds and went away . This wasn't a heat ticking noise .....
07 F-250 Outlaw , Rough Country 6 inch lift , 37-13.5 R20 Nitto Mud Grapplers , MBRP 5" Exhaust , 08 Mirrors , S&B intake , 5% Tint sides and back , 35% windshield .
Bad Night is offline
post #2 of 10 Old 08-04-2013, 06:11 PM Thread Starter
Bad Night's Avatar
Quoted: 5 Post(s)
Anyone have any ideas here ???? I wondering if there is a tranny problem that is putting the truck under load .....
post #3 of 10 Old 08-05-2013, 04:18 PM Thread Starter
Bad Night's Avatar
Quoted: 5 Post(s)
No 6.4 experts out there ? I am good with 7.3s and 6.0s just don't know much about the 6.4s . Anyone ever hear of anything even remotely close to the situation I have ?
post #4 of 10 Old 08-05-2013, 04:22 PM
Powerstroke Techie
After a cold soak what does your EGT read key on, engine off?
Sounds to me like the sensor is dickered, or you've got a serious overfueling condition.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #5 of 10 Old 08-05-2013, 04:33 PM
theplumbingmedic's Avatar
I am following this and not to sound like a zimmpleton but what exactly is a cold soak ?
2010 F350 lariat cc sb srw
H&S Black Maxx,S&B CAI,,Readylift leveling kit,,GY 325/60/20,Smoked Recon: tail lights,cab lights,3rd brake light and tow mirror lights,AVS smoked window vents,20% window tints,Curt front mount hitch,Rear hitch mounted lights,Sinister coolant filter,PMF dual steering stabilizer,PMF traction bars 51 Gal. Titan tank,Bilstein 5100`s,Rudy`s up pipes,ARP studs,RCD egr delete w/ elbow,AFE cold side pipe,AFE 4"dp, AFE 5"
exhaust
theplumbingmedic is offline
post #6 of 10 Old 08-05-2013, 05:02 PM Thread Starter
Bad Night's Avatar
Quoted: 5 Post(s)
I think he means leaving it sit until it is completely cooled down . I will check in the morning and see what it reads .
post #7 of 10 Old 08-06-2013, 11:56 AM Thread Starter
Bad Night's Avatar
Quoted: 5 Post(s)
Okay so key on engine off after letting the truck sit all night the insite says exhaust temps are 140 ........ It's only 75 degrees out .
post #8 of 10 Old 08-07-2013, 04:47 AM
140, mine does the same with EDGE CTS, that might the lowest the sensor goes.
GSchretter is offline
post #9 of 10 Old 08-07-2013, 04:51 AM
1. Run in stock (no high HP gains), problem continue?
2. Have you done an EGR delete?
3. Blackstone report? Might be worth it.
4. Have injectors check
post #10 of 10 Old 08-07-2013, 01:32 PM Thread Starter
Bad Night's Avatar
Quoted: 5 Post(s)
Thanks for the reply . I have not deleted the egr but will be doing that very soon . I will check/try the rest of what you said and see where it stands . I don't drive it everyday so I haven't been in too big of a hurry to work on it plus I have been really busy lately so it keeps getting pushed back .
