loosing coolant, gaining oil - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-02-2013, 08:53 PM Thread Starter
I have a 2008 f350 6.4l with full egr delete and dpf delete.
Ive been gaining oil and mysteriouly losing lots of coolant.
I fill it up to the cold fill line and in about 30 minutes its down to the bottom. And ive been blowing white smoke at idle
komatsu74 is offline
post #2 of 10 Old 08-03-2013, 06:35 AM
Sounds like you better start looking for head studs and gaskets. Get that looked at, and soon.
B. Adams is offline
post #3 of 10 Old 08-03-2013, 06:50 AM
Your timing cover may have a hole in it from cavitation.
g4dadon is offline
post #4 of 10 Old 08-04-2013, 05:27 PM
RHKA's Avatar
+1 looks like those heads is coming off. Goodluck.
ETA: how many miles on your 6.4?
2008 F-350 LARIAT CC LB DRW 4x4
6" FABTECH LIFT
22" AMERICAN FORCE RIMS, TOYO OPEN COUNTRY A/T LT325/50R22
SPARTAN TUNER(300 HP TUNE WHEN EMPTY)
5" DIAMOND EYE EXHAUST TURBO BACK
RHKA is offline
post #5 of 10 Old 08-04-2013, 07:33 PM Thread Starter
Thanks everyone, my truck has 144,000 miles
It was doing the same thing until i changed the oil and deleted the egrs. After i deleted them it still used coolant like before but no smoke and nopowerloss even the cel went off, but now the smoke is back and is hard to start witg powerloss
post #6 of 10 Old 08-05-2013, 06:54 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
^^ This would be my guess.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #7 of 10 Old 08-12-2013, 08:45 AM
Quoted: 45 Post(s)
Some shops will use lube upon request. Good luck and let us know how it turns out.
2015 F350 DRW Platinum, SCT X4, EDGE CTS2, aFe PDS, AirLift 5000 Ultimate & Wireless Air, Lund LED Bull Bar, RC Grille bar, B&W 5th Wheel, Stark LED Lighting
2010 F250, H&S Mini Maxx, aFe PDS, Diamond Eye 4", Pro Comp Nitro 2.5", Bilstein 5100, SmittyBilt Bull Bar, Bushwacker Pocket Style, B&W Slider, Firestone Ride-Rite, Fuel Hostage 20x10, Pioneer/Kicker/JL Audio
RUFFSTUFF is offline
post #8 of 10 Old 09-07-2013, 05:42 PM
x2 on cavitation....good luck, let us know
toddster is offline
post #9 of 10 Old 09-07-2013, 07:09 PM
Does sound like you need a new front cover. You can pull the water pump off and sometimes see the tiny holes through the cover that the cavitation caused. As far as the heads, 6.4's seldom have head gasket issues,at least that I've seen come in the shop. I feel for ya man
Old_Blue is offline
post #10 of 10 Old 09-07-2013, 10:43 PM
srjd's Avatar
Quoted: 2 Post(s)
Head gasket issues are more common on the 6.4 then most ppl think. But sounds like cavitation
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
