Howling Noise - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-21-2013, 06:24 AM Thread Starter
Howling Noise
I have a 2008 F250 diesel with 80,000 miles. About 2 week ago i started to hear a howling noise at 1,000-1,500rpm's. The new noise would continue for about 20 seconds then disappear. Recently it started to get more frequent. No loss of power but it seems to go into regen more often. The truck is out of warranty without any aftermarket parts. Sounds to me like it is coming from the turbo but I am not sure. It doesn't sound like a whine but more like wind howling.
JNyzz is offline
post #2 of 6 Old 07-22-2013, 08:54 AM
Is it a growly kind of sound? Might just be your fan clutch engaging.
And I'm just going to assume you meant 1,000-1,500 RPM. Either that or you're pushing your diesel way too hard.
B. Adams is offline
post #3 of 6 Old 07-22-2013, 09:19 AM
I have the same noise (howling) when my truck is running. I believe the noise is coming from the muffler after looking the truck over. Mine happens as soon as I start the truck. I haven't worried too much about it, I am going to install a new exhaust soon. Hope this helps.
99.5 F250 7.3 (Sold)
2006 F350 6.0 CC LB SRW FX4
Pro Comp 2.5 Leveling Kit
New Premium FICM from Ed
IPR GEN 2 EGR Delete w/ Up Pipe
Flo Pro 4" Turbo Back w/muffler
Blue Spring Mod
SCT Livewire ts
Ag Street Tune by Eric
NCDeerHunter is offline
post #4 of 6 Old 11-13-2013, 08:54 PM
Nate5281's Avatar
fuel cooler/turbo actuator cooler low on coolant. There is a little coolant resevoir to the right of your turbo actuator. Top it up, then on the turbo actuator there is a 5/16 hex key bleeder. take that off and top it up with coolant as well. this should stop fix your problem.
Nate5281 is offline
post #5 of 6 Old 11-25-2013, 09:42 AM
Had kinda the same sound as you with the exception that it would make a little "screech" and quit making the howl noise. Sound would come back. Turned out to be the High Pressure Turbo. The bearing was loose and the wheel was rubbing inside the housing. Maybe something to think about
rkmarcum is offline
post #6 of 6 Old 11-25-2013, 09:46 AM Thread Starter
Nate was correct with the above post. Thx
JNyzz is offline
