c02 test relaibility? 6.4 blown head. - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-19-2013, 12:37 PM Thread Starter
If my truck failed a c02 test how certain is it that my head gasket is blown?
What other tests can I have done to verify the current state of my head?
Beatrice is offline
post #2 of 9 Old 07-21-2013, 06:20 AM Thread Starter
Sorry what my truck failed was the dye test
Beatrice is offline
post #3 of 9 Old 07-21-2013, 06:23 AM
Powerstroke Techie
If your truck also has leaking EGR cooler(s) on it, this can cause positive results on the dye test.
Measure the cooling system pressure when you're honking on the truck - if it rises to or exceeds 16psi you will need to pressure test the EGR coolers first, then evaluate the head gaskets.
What are the symptoms you are experiencing to get you to the point where you got the cooling system checked for combustion gas?
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #4 of 9 Old 07-21-2013, 10:25 AM Thread Starter
Im not experiencing any real symptoms, i just bought the truck from an out of town dealer. The alternator went out five days later i took it in to have it replaced at my trusted local shop and asked they go over the engine as it is a new purchase. They did the dye test and it failed, it also had a slight misfire on cylinder six. I took the truck back to the dealer, they did a pressure test and didnt find issues. They then would not tell me if the truck passed or failed a dye test they instead said it was an out dated test and wouldnt matter anyways. Im really trying to understand what to believe.
Beatrice is offline
post #5 of 9 Old 07-21-2013, 10:35 AM Thread Starter
By pressure test i dont mean a cylinder pressure test, i believe they just monitored the pressure in the coolent system,
Beatrice is offline
post #6 of 9 Old 07-21-2013, 11:59 AM
WoodBoy's Avatar
That's all that matters. The cylinder 6 misfire though would really have my attention
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #7 of 9 Old 07-21-2013, 01:03 PM Thread Starter
I have to also include that there was also a leak found in my coolent line, this made me feel the dye test was so important. My thought process is if there is a leak in the coolent system what good is a pressure test. Am i far off?
Beatrice is offline
post #8 of 9 Old 07-22-2013, 06:51 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Are you thinking an injector is causing the misfire?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #9 of 9 Old 07-22-2013, 08:04 PM
matted2thefloor's Avatar
Cylinder misfire can also be attributed to coolant being introduced during the combustion process (a compromised head gasket). Which in turn, could explain the questionable dye test results. It wouldn't take much coolant at all to produce a misfire though. Has the cooling system ever required a top off?
08 F350 CCLB 4x4 Lariat Job 3
Over 200k on the ticker... Living healthy with the help of some goodies!
matted2thefloor is offline
