Leaking oil through exhaust - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-16-2013, 09:32 PM Thread Starter
2008 f350 6.4l Leaking oil through exhaust
Ok im basically new to diesel as this is my first its a 2008 f350 6.4L, I bought it tuned with a minimaxx and dpf delete and s&b, I was told(by the seller) it needed an horizontal egr cooler so I decided to just go with a delete kit.
Before installing the kit it would blow white smoke at idle and when accelerating, at startup it would blow lots of black and white smoke and I felt like it had no power when accelerating, also was losing coolant out of the degas.
The engine never overheated and idled perfectly
After I finished installing the kit I started up the truck and no smoke came out as it did before, drove it around the neighborhood and no powerloss but still some white smoke from the exhaust when accelarating. I parked it back in my driveway and noticed there was oil coming out of the exhaust which did not happen before the delete So Im wondering what you guys think is the problem is, turbo seals?
komatsu74 is offline
post #2 of 12 Old 07-17-2013, 06:03 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
sounds like its the turbo seals.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 12 Old 07-17-2013, 10:57 AM Thread Starter
Thanks for the knowledge
It also had alot of oil sludge in the intercooler tube so i cleaned that but im guessing theres alot more in intercooler itself, should that be cleaned also?
post #4 of 12 Old 07-17-2013, 11:03 AM Thread Starter
The intercooler tube also had alot of oil sludge so i cleaned that out but im guessing the intercooler itself has alot, should the intercooler be cleaned too?
post #5 of 12 Old 07-17-2013, 11:57 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Its normal to have oil there because of the CCV system. I would just clean it out as best you can. Unless you do a CCV mod there will always be oil in the intercooler tubes.
08 F350 cc/sb 4X4
post #6 of 12 Old 07-17-2013, 01:10 PM Thread Starter
Sounds good but what should i clean it with? And is their a reason why it says i have 2 mpg on the dash
post #7 of 12 Old 07-17-2013, 01:58 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
From what I have read you can take off the intercooler and clean it with simple green and water. Then rinse really well and let it dry.
08 F350 cc/sb 4X4
post #8 of 12 Old 07-17-2013, 06:08 PM Thread Starter
Just to make sure is leaking turbo seals the only thing that would cause oil through the exhaust?
post #9 of 12 Old 07-18-2013, 06:07 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
That's the only thing I can think of. Hopefully someone else will chime in to confirm.
08 F350 cc/sb 4X4
post #10 of 12 Old 07-29-2013, 08:54 PM
thomas5853's Avatar
Send a message via AIM to thomas5853
I had oil leaking of the exhaust on my 6.0 and they said it was the turbo seal that caused it. But the cause of the leak, even with a new turbo charger, was the failure of my make shift CCV kit. It caused excessive back pressure on the driver side so that caused more pressure on the passenger side. The excessive pressure caused the turbo seal to fail.
2010 F350 Lariat DRW FX4
thomas5853 is offline
