cam shaft and crank shaft sensor - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-13-2013, 07:53 PM Thread Starter
We have an 08 f250. it ran low on fuel. It would not start even after the tank was filled. It threw codes for the crank and cam shaft sensors. Replaced the cam shaft sensor. It started and ran for about 10 seconds. we then replaced the crankshaft sensor. It didnt start. We tried another (new) sensor hoping the first was bad. It still will not start and keeps throwing the code for the crankshaft sensor. What to do next?
albertsdiesel is offline
post #2 of 4 Old 07-13-2013, 07:55 PM Thread Starter
It has a Banks Fuel Management System if that helps.
post #3 of 4 Old 07-25-2013, 09:50 PM
halfregulater's Avatar
Did it "run low" or RUN OUT??
halfregulater is offline
post #4 of 4 Old 07-25-2013, 10:04 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
Are you getting fuel to the filter under the hood?
Crack that filter housing open and have a friend cycle the key to ensure you have fuel getting up there.
Sent from AutoGuide.com App
2005 F350 CCLB FX4
juniorssrollin is offline
