Whiteish blue smoke on heavy throttle - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-12-2013, 04:13 PM Thread Starter
01excursion on stars's Avatar
2008 f250 has spartan tuner just started to smoke on some heavy acceleration also when smokes runs rough, losses power thanks
01excursion on stars is offline
post #2 of 10 Old 07-12-2013, 09:16 PM Thread Starter
Any body have any ideas
post #3 of 10 Old 08-20-2013, 02:19 PM
fiderius22's Avatar
What color smoke?
Sent from AutoGuide.com App
08 6.4 F-250
ARP studs
Rudy's coated/machined pistons
CX Aluminum intercooler
No Limit ic pipes
ccv Reroute
AFE MF intake
PTP EGR delete w/ elbow
Diamond Eye 5" dp back with MBRP 7" tip
H&S Mini HD300
PATC triple disc billet tc
PATC stage 3 built trans
6" 4-link rough country lift
PMF stage 2 trac bars with gussets and block mount
20x10 XD Revolvers with Federal 35 MTs
Advantage Max-4 wrapped bumpers/grille
Reflexxions steel cowled hood
5% tint
Kenwood nav/dvd
fiderius22 is offline
post #4 of 10 Old 08-20-2013, 02:21 PM
fiderius22's Avatar
Oh sorry. In the title! Cracked piston maybe. See how much blow by you have. These trucks are known for blow by but excessive points to pistons. Any codes? Does it ever seem to be missing?
08 6.4 F-250
ARP studs
No Limit ic pipes
ccv Reroute
AFE MF intake
H&S Mini HD300
5% tint
Kenwood nav/dvd
post #5 of 10 Old 08-20-2013, 04:12 PM Thread Starter
There is a code and it loses power if u let off and get back on it it is fine the code is p0088
post #6 of 10 Old 08-20-2013, 04:44 PM
fiderius22's Avatar
I believe 088 is hpfp. It would be a contribution balance code or misfire code most likely on a piston.
08 6.4 F-250
ARP studs
No Limit ic pipes
ccv Reroute
AFE MF intake
H&S Mini HD300
5% tint
Kenwood nav/dvd
post #7 of 10 Old 08-20-2013, 05:02 PM Thread Starter
That's what I have been reading that is hpfp do u know if u have to remove the cab
post #8 of 10 Old 08-20-2013, 05:08 PM
fiderius22's Avatar
Yes sir I believe ya do. Not bad to do though. Have a shop evac the ac and then remove Headlights, lot of harnesses, parking break cable, batteries and battery trays, intake, degas res and a bunch of hoses and cab bolts. I'm sure there's a complete write up on here somewhere. Otherwise, master tech has a you tube video walking ya through it.
08 6.4 F-250
ARP studs
No Limit ic pipes
ccv Reroute
AFE MF intake
H&S Mini HD300
5% tint
Kenwood nav/dvd
post #9 of 10 Old 08-20-2013, 06:13 PM Thread Starter
We have done it once wasn't sure if the was a way to do it with out removing the cab
post #10 of 10 Old 08-21-2013, 06:37 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Anything can be done cab on I believe if you have the patience. There is a member on PSA white monster (shane) and he only works on these trucks with the cab on.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
