oil problem - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-11-2013, 07:02 PM Thread Starter
oil problem
I changed my fuel rail sensor a week ago ran good took to ford had them run there diagnostic test on truck everything was good. Today I could smell diesel looked under hood on passenger side oil was all over air cleaner hood couldn,t see where oil is coming from rev truck up still nothing. anyone no what's going on.
williehood is offline
post #2 of 6 Old 07-12-2013, 07:09 AM Thread Starter
I was changing oil this morning and found diesel fuel in it I wonder if that has something to do with it I have only had truck for a little over a month
post #3 of 6 Old 07-12-2013, 09:29 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Is there a knock? Is it throwing any cylinder contribution codes?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #4 of 6 Old 07-12-2013, 09:40 AM
Watch your oil levels. If they go up, you have a fuel leak in the engine. Usually one of the jumper lines from the common rail to an injector. That won't spray oil outside though.
Maybe the vent tube cracked? Runs from the front of the oil fill housing down the right head and block
Hauser is offline
post #5 of 6 Old 07-12-2013, 10:36 AM Thread Starter
It is not knocking.and has not thrown any codes runs and drive good
post #6 of 6 Old 07-12-2013, 10:38 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Maybe in that case like hauser said maybe the ccv tube broke or came loose. Check that first.
08 F350 cc/sb 4X4
