Blowing boost tube - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-01-2013, 02:31 PM Thread Starter
Blowing boost tube
Hey guys so I keep on blowing off my hot side boost tube. Ill put it back on, then within a mile it'll blow right off again. I've cleaned it many times and it doesn't help. Any ideas? It has a dent on the bottom right side of the tube. I thought it came like that normally, but idk. Is that normal?
ColtonH00 is offline
post #2 of 3 Old 07-02-2013, 05:44 AM
Quoted: 2 Post(s)
get some new boots. diesel site makes some really good ones. they are a little bit longer than the stock boots.
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #3 of 3 Old 07-02-2013, 06:33 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
New boots would help. Also clean all connections good with brake cleaner and put a little hairspray. Also make sure boost tube is not egg shaped
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
Tags
6.4 , blowing , boost , problem , tube
