alot of fuel in my oil. headgaskets gone? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 06-26-2013, 10:42 AM Thread Starter
My dad has a 09 with 48k miles on it the fuel n oil filters have always been change at 4500miles on he dot .
The truck is 100% stock because we are still in the last few months of warrenty.
What happened was we were driving around n all of a sudden the truck got a real rough idle, the truck started drinking fuel n the engine light came on n reduced engine power flashed up but when ford scanned the code no code popped up so we brought it back home n when we went to try n diagnose the issue we dropped the oil a ton of fuel was mixed in with it so we r thinking headgaskets what do you guys think?
wannatruck is offline
post #2 of 17 Old 06-26-2013, 11:16 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Because of the regen process fuel in the oil is common. It is often referred to as "making oil". The only real solution is to change oil more frequently or delete. It is uncommon for a stock truck to blow the head gaskets.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 17 Old 06-26-2013, 11:30 AM
freshcutmullet's Avatar
4500 miles on oil changes seems acceptable with regens going on. Sounds like an injector gone south
Sent from AutoGuide.com App
freshcutmullet is offline
post #4 of 17 Old 06-26-2013, 11:33 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
an injector is another possibility especially since you stated it has a rough idle. I guess it depends on how much fuel was in the oil. Do you have white smoke at start up?
08 F350 cc/sb 4X4
post #5 of 17 Old 06-26-2013, 11:39 AM Thread Starter
A lot of white smoke. And the egr cooler and egr was replaced 8k miles ago. It was fixed under warrenty by ford
The injectoes was the only other thing I was thinking of
post #6 of 17 Old 06-26-2013, 11:42 AM Thread Starter
So you guys thinking more of a injector issue?
It sucks we are from philly and we are on vacation in cedar point ohio so we are kind of stuck
post #7 of 17 Old 06-26-2013, 11:52 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Yup sounds like an injector. It is worth getting fixed asap. Last thing you want is for it to melt a piston.
08 F350 cc/sb 4X4
post #8 of 17 Old 06-26-2013, 12:00 PM
JUGGS's Avatar
Man, good luck with this. Hope y'all make it home safe one way or another.
2005 F250 Lariat CCSB/170k mi./6sp Handshaker
Don't Worry
Dieselsite coolant filter, CAT ELC, Bulletproofed and monitored by BPD
Be Happy
SCT SF3, 4" Flo Pro, 2.5" Readylift SST, 35" GoodYear Fierce Attitude M/T's
JUGGS is offline
post #9 of 17 Old 06-26-2013, 12:37 PM Thread Starter
I hope so too^ thanks man
And ok thanks for ur help guys. Mind as well upgrade injectors of ford doesn't cover it
What ones do you guys recommend. We tow a 14k fifth wheel camper a lot in the summer and we plan on doing egr delete dpfe delete exhaust and a tune as sokn as warrant is up so what injectors would go well with that combo?
post #10 of 17 Old 06-26-2013, 01:26 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Personally I would stick with stock injectors. Most people have a hard time maintaining rail pressure with anything over stock injectors. You would need to upgrade the fuel system (dual fuelers).
08 F350 cc/sb 4X4
